Categories
- All Categories
- Oracle Analytics and AI Learning Hub
- 53 Oracle Analytics and AI Sharing Center
- 19 Oracle Analytics and AI Lounge
- 290 Oracle Analytics and AI News
- 57 Oracle Analytics and AI Videos
- 16.3K Oracle Analytics and AI Forums
- 6.5K Oracle Analytics and AI Labs
- Oracle Analytics and AI User Groups
- 112 Oracle Analytics and AI Trainings
- 21 Oracle Analytics and AI Challenge
- Find Partners
- For Partners
Customization of Oracle Standard Check Printing: Issue with printing check info at fixed position:
Summary
Content
Dear Experts,
I am working on new check printing format ( Used the oracle standard check template and customizing it) which is to print invoice data on first half of the page and the second half is to print check information(assuming a page a table with single column and 2 rows).
Inside the first row, I created another table for displaying invoice data like invoice number, invoice amount, amount paid
Inside the second row, I created another table for displaying check info like check number, amount, bank info and payee name and address.
Facing an issue that unable to fix the table size which results to moving check info to next page when there are more invoices. I want to fix the check data at the bottom of the page as always and it should not above or below the page due to less or more invoices case.
Could you please help me to resolve the issue.
Attached the sample template for your review and fix.
Thanks,
Karthik
Version
Oracle R12.2.6
Answers
Hi Karthik,
Were you able to resolve this issue? We're currently encountering the same issue on our end where we need to have the invoice details before the check. If there are multiple invoices or a lenghty invoice description, the check info is being pushed to the next page. Your response would be much appreaciated.
Thanks,
Sam0 -
Keep your check table in footer to resolve the issue. if you keep your table in footer then it will be not moved to next page.In footer we can place the tag name where your fields are there ex : <?checknum?>
0
