Categories
- All Categories
- Oracle Analytics and AI Learning Hub
- 54 Oracle Analytics and AI Sharing Center
- 26 Oracle Analytics and AI Lounge
- 312 Oracle Analytics and AI News
- 57 Oracle Analytics and AI Videos
- 16.4K Oracle Analytics and AI Forums
- 6.7K Oracle Analytics and AI Labs
- Oracle Analytics and AI User Groups
- 117 Oracle Analytics and AI Trainings
- 24 Oracle Analytics and AI Challenge
- Find Partners
- For Partners
OTBI analysis - problem with left outer join
Hi,
I tried this query but it seems that it's not working. It's throwing an error (Formula syntax is invalid). I'm using this query to determine if employees have submitted their reported hours or not. Do you also have documentation regarding OTBI joins?
select t1.t
,ifnull(t2.c,upper('wo')) as m
from
select all "Time"."Calendar Date" as t
from "Workforce Management - Reported Time Cards Real Time"
)t1
left outer join
,"Reported Time Cards"."Reported Hours" as n
,cast("Reported Time Cards"."Reported Hours" as character) as c
)t2
on(
t1.t = t2.t
Thank you in advance
Best Answer
Hi,
On page /analytics/saw.dll?IssueRawSQL this SQL execute with success. No error message.
and if you add a sort
NOTE This will tell you in anyone entered a timecard that day but all status of timecards whether they submitted for approval or just saved some time for later without submit for approval.
Here is your user guide
Oracle® Fusion MiddlewareLogical SQL Reference Guide for Oracle Business Intelligence Enterprise Edition
Release 12c (12.2.1.3.0) E80604-01Au gust 2017
2
Answers
@Nathan CCC , I've stumbled into this posting due to a similar problem I'm facing with BI outer joins. After struggling with finding the right code to get my two tables to connect, your example was just what I was looking for. It worked! I can't thank you enough, really appreciate this.
Take care,
Justin1
