Skip to Main Content
Database Software
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
help with error "interface not supported without a spatial index"
Sergio Palma HidalgoJul 31 2018 — edited Aug 3 2018
I have a problem! I'm new in Oracle Spatial, but I've been working with pl/sql for a while. The thing is, I need to look for points (x,y) from geometry attribute from table B, inside geometry attribute (polygons) from table A. The issue: both tables have different data inside geometry field.
More details:
CREATE TABLE A
GEOMETRY MDSYS
.SDO_GEOMETRY,
MANZENT VARCHAR2
(255 BYTE),
CREATE TABLE B
ID_GIS NUMBER(8,0),
GEOMETRY MDSYS
.SDO_GEOMETRY,
When I run the Query:
SELECT A.MANZENT, A.GEOMETRY
FROM A, B
WHERE MDSYS.SDO_RELATE(A.GEOMETRY, B.GEOMETRY, 'mask=touch+coveredby') = 'TRUE';
It throw an error:
ORA-13226: Interface Not Supported Without a Spatial Index
ORA-06512: at "MDSYS.MD", line 1723
ORA-06512: at "MDSYS.MDERR", line 8
ORA-06512: at "MDSYS.SDO_3GL", line 70
13226. 00000 -  "interface not supported without a spatial index"
*Cause:    The geometry table does not have a spatial index.
*Action:   Verify that the geometry table referenced in the spatial operator
           has a spatial index on it.
Well, I looked for the Index in both tables, and it seems to be ok!:
  CREATE INDEX "DS_FDOX"."A_IDX" ON "DS_FDOX"."A" ("GEOMETRY")
   INDEXTYPE IS "MDSYS"."SPATIAL_INDEX" ;
  CREATE INDEX "DS_FDOX"."B_IDX" ON "DS_FDOX"."B" ("GEOMETRY")
Both tables has their metadata (ALL_SDO_GEOM_METADATA and USER_SDO_GEOM_METADATA) but; attribute RID NULL :
The SRDI should be 32719.
*** UPDATE ***
Checking the Index Status i get error on table A spatial Index:
select table_name, index_name, status, ityp_name, domidx_status, domidx_opstatus
from USER_INDEXES
where ityp_name='SPATIAL_INDEX';
A_IDX  I got "FAILED" in DOMIDX_OPSTATUS!
So, I deleted the spatial index A_IDX, but when I'm creating again the index:
CREATE INDEX A_IDX ON A (GEOMETRY)
INDEXTYPE IS MDSYS.SPATIAL_INDEX;
I get this error:
ORA-29855: error occurred in the execution of ODCIINDEXCREATE routine
ORA-13249: internal error in Spatial index: [mdidxrbd]
ORA-13249: Error in Spatial index: index build failed
ORA-13249: Error in spatial index: [mdrcrtxfergm]
ORA-13249: Error in spatial index: [mdpridxtxfergm]
ORA-13200: Internal error [ROWID:AAB64sAAEAAAGvsAAA] in spatial indexing
ORA-13206: Internal error [] while creating the spatial index
ORA-13365: Layer SRID does not match geometry SRID
ORA-06512: in "MDSYS.SDO_INDEX_METHOD_10I", line 10
The metadata from table A, in tables USER_SDO_GEOM_METADATA and ALL_SDO_GEOM_METADATA; in both tables the attribute SRID is null.
But the metadata from table B in tables USER_SDO_GEOM_METADATA and ALL_SDO_GEOM_METADATA is SRID 32719.
How can I determine the right SRID for table A? To  update the attribute SRID at tables USER_SDO_GEOM_METADATA and ALL_SDO_GEOM_METADATA.
More details:
- USER_SDO_GEOM_METADATA for table A:
Select * from USER_SDO_GEOM_METADATA WHERE table_name = 'A';
Result:
Thanks in advance!
Edited by: Sergio Palma H.
This post has been answered by [Deleted User] on Jul 31 2018
Jump to Answer
Comments
Processing
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Aug 31 2018
Added on Jul 31 2018
11 comments
