Discussions
Categories
- 17.9K All Categories
- 3.4K Industry Applications
- 3.3K Intelligent Advisor
- 63 Insurance
- 535.7K On-Premises Infrastructure
- 138.1K Analytics Software
- 38.6K Application Development Software
- 5.6K Cloud Platform
- 109.3K Database Software
- 17.5K Enterprise Manager
- 8.8K Hardware
- 71K Infrastructure Software
- 105.2K Integration
- 41.5K Security Software
Tech Article: How to Build Software Defined Networks Using Elastic Virtual Switches - Part 1
Using Oracle Solaris 11.2
by Orgad Kimchi with contributions from Girish Moodalbail
This article demonstrates how to use the Elastic Virtual Switch (EVS) feature of Oracle Solaris to set up two compute nodes that host four Oracle Solaris Zones and then set up two elastic virtual switches across the two compute nodes to isolate the network traffic for two cloud tenants.
Table of Contents
About the Elastic Virtual Switch Feature of Oracle Solaris
EVS Building Blocks
Architecture We Will Use
Tasks We Will Perform
Prerequisites
Setting Up SSH Authentication
Setting Up the EVS Controller
Configuring compute-node1
Setting Up the First Zone on compute-node1
Setting Up the Second Zone on compute-node1
Configuring compute-node2
Setting Up the Third Zone on compute-node2
Setting Up the Fourth Zone on compute-node2
Testing Our Final Configuration
Summary
See Also
Acknowledgment
About the Authors
Oracle Solaris 11.2 enhances the existing, integrated software-defined networking (SDN) technologies provided by earlier releases of Oracle Solaris to provide much greater application agility without the added overhead of expensive network hardware. It now enables application-driven, multitenant cloud virtual networking across a completely distributed set of systems; decoupling from the physical network infrastructure; and application-level network service-level agreements (SLAs)—all built in as part of the platform. Enhancements and new features include the following:
- Network virtualization with virtual network interface cards (VNICs), elastic virtual switches, virtual local area networks (VLANs), and virtual extensible VLANs (VXLANs)
- Network resource management and integrated, application- level quality of service (QoS) to enforce bandwidth limits on VNICs and traffic flows
- Cloud readiness, a core feature of the OpenStack distribution included in Oracle Solaris 11
- Tight integration with Oracle Solaris Zones
The Elastic Virtual Switch (EVS) feature provides a built-in distributed virtual network infrastructure that can be used to deploy and manage virtual switches that are spread across several compute nodes. These compute nodes are the physical machines that host virtual machines (VMs).
An elastic virtual switch is an entity that represents explicitly created virtual switches that belong to the same Layer 2 (L2) segment. An elastic virtual switch provides network connectivity between VMs connected to it from anywhere in the network.
Note: With EVS, all references to the term virtual machines (or VMs) specifically refer to Oracle Solaris Zones and Oracle Solaris Kernel Zones—that is, solaris
(5) and solaris-kz
(5) branded zones, respectively.
The Benefits of EVS
EVS technology provides better manageability, flexibility, and observability. EVS is tightly integrated with the newly introduced Oracle Solaris Kernel Zones as well as with native zones, allowing a zone's VNIC to easily connect to an elastic virtual switch.
If you are familiar with the Oracle Solaris Zones administration commands, such as zonecfg
and zoneadm
, adding EVS support will be very easy with a minimal learning curve.
EVS provides centralized management and observability for ease of use, and for the monitoring of resources across all the nodes, in a single view. It provides centralized management of the following:
- MAC addresses and IP addresses for the virtual ports
- SLAs, on a per-virtual-switch or per-virtual-port basis
It also enables the monitoring of runtime network traffic statistics for the virtual ports. In addition, EVS forms the back end for OpenStack networking, and it facilitates inter-VM communication (on the same compute node or across compute nodes) using either VLANs or VXLANs.
Management is performed through easy-to-use administration tools or through OpenStack's Horizon Dashboard using the OpenStack Neutron plugin for EVS.
Fine-grained SLAs, such as network bandwidth enforcement, can be per VM or per tenant, including many VMs. In addition, if you migrate a VM to a different physical system, the SLA enforcement remains intact.
EVS can be deployed on multiple network fabrics. Currently EVS supports VXLANs and VLANs for maximum flexibility, and for easy integration into your existing environment. Its architecture is fabric-independent, and can be extended in the future to support additional types of network fabrics.
VLANs and VXLANs
VLANs have been used in networking infrastructures for many years now, and they can be used to enforce L2 isolation. Support for VLANs is now available in most operating systems, NICs, network equipment (for example, switches, routers, firewalls, and so on) and also in most virtualization solutions. As virtualized data centers scale and grow, some of the shortcomings of VLAN technology start to emerge, and cloud providers need some extensions to the basic VLAN mechanism.
The first issue is the VLAN namespace itself. The IEEE 802.1Q specification defines a VLAN ID to be 12 bits, which restricts the number of VLANs to 4096. (Usually some VLAN IDs are reserved for "well-known" uses, which restricts the range further.) Cloud-provider environments require accommodating different tenants in the same underlying physical infrastructure. Each tenant may in turn create multiple L2 and layer 3 (L3) networks and other network components, such as firewalls and load balancers, within their own slice of the virtualized data center. This drives the need for a greater number of L2 networks.
The second issue has to do with the operational model for deploying VLANs. Although the VLAN Trucking Protocol (VTP) exists as a protocol for creating, disseminating, and deleting VLANs, as well as for pruning them for optimal extent, most networks disable it.
Manual VLAN setup can be a tedious task, especially in a large network environment when you need to create the VLANs on the global zones in addition to creating them on the network switches. In order to create elastic and isolated virtual networks in the cloud, you can enable the GARP VLAN Registration Protocol (GVRP).
GVRP reduces the chances for errors in VLAN configuration by automatically providing VLAN ID consistency across the network. In addition, GVRP enables a device to dynamically create 802.1Q-compliant VLANs on links with other devices, such as network switches that are running GVRP. The use case for this technology is a cloud environment in which a new VLAN needs to be added automatically on the network, for example, when a new user starts to use the cloud infrastructure and you want to assign a new VLAN in order to segregate the new user's network traffic from other users.
In addition, a VLAN can be removed when all the interfaces that used this VLAN have been removed. In this way, you can reuse the VLAN for another user.
The global zone dynamically sends updates to the network switch when VLANs are configured on the data link. The network switch updates its VLANs database with the VLAN associated with the switch port.
Note: Only the host OS (global zone) would be able to send GVRP messages to the fabric, so GVRP wouldn't allow a tenant guest to attack the network by sending a message to the fabric. For more information about GVRP, see Managing Network Virtualization and Network Resources in Oracle Solaris 11.2.
The VXLAN specification (RFC-7348) provides a network virtualization scheme that overlays L2 over L3. VXLAN uses L3 multicast to support the transmission of multicast and broadcast traffic in the virtual network, while decoupling the virtual network from the physical infrastructure. VXLAN uses a UDP-based encapsulation to tunnel Ethernet frames. VXLAN can extend the virtual network across a set of Oracle Solaris servers, providing L2 connectivity among the hosted VMs.
The VXLAN ID space is 24 bits. This doubling in size allows the namespace to increase to over 16 million unique identifiers, which should provide sufficient room for expansion for years to come. VXLANs use the Internet Protocol (IP)—both unicast and multicast—as the transport medium. The ubiquity of IP networks and equipment allows the end-to-end reach of a VXLAN segment to be extended far beyond the typical reach of VLANs using 802.1Q today. For more information about VXLANs, see "VXLAN in Solaris 11.2."
Note: VLANs and VXLANs can coexist on the same network cloud infrastructure.
EVS Building Blocks
EVS building blocks include the EVS manager, the EVS controller, EVS clients, EVS nodes (compute nodes), an IP network (also known as an IPnet), virtual ports (VPorts), and tenants.
Figure 1. Some of the EVS building blocks
EVS Manager
The EVS manager is the entity that communicates with the EVS controller to define the L2 network topologies and the IP addresses that must be used on the L2 networks. The EVS manager communicates with the EVS controller by using the evsadm
command. The EVS manager and the EVS controller can also be on the same Oracle Solaris node.
Note: For simplicity, in this article, the EVS manager and the EVS controller will be on the same Oracle Solaris node.
EVS Controller
The EVS controller is the main component of the EVS framework and has a global view of the virtual network infrastructure. The EVS controller provides functionality for the configuration and administration of an elastic virtual switch and all the resources associated with it. It provides an API to the EVS manager and EVS clients in order to configure and monitor the EVS resources.
In OpenStack, the Neutron network virtualization service provides network connectivity for other OpenStack services on multiple OpenStack systems and for VM instances. In Oracle Solaris, network virtualization services are provided through the Elastic Virtual Switch capability, which acts as a single point of control for creating, configuring, and monitoring virtual switches that span multiple physical servers. Applications can drive their own behavior for prioritizing network traffic across the cloud. Neutron provides an API for users to dynamically request and configure virtual networks.
In a multinode OpenStack architecture, the network node is responsible for the network services and it requires configuring both the EVS controller and the Neutron DHCP agent and, optionally, the Neutron L3 agent. EVS forms the back end for OpenStack networking, and it facilitates communication between VM instances, using either VLANs or VXLANs. For more information about multinode OpenStack architectures, see Installing and Configuring OpenStack in Oracle Solaris 11.2.
Note: Part 2 of this series will cover EVS in the context of OpenStack.
The EVS controller is associated with properties that you can configure by using the evsadm set-controlprop
subcommand. To implement the L2 segments across physical machines, you need to configure the properties of an EVS controller with information such as the available VLAN IDs, the available VXLAN segment IDs, or an uplink port for each EVS node.
Note: You must set up only one physical machine as the EVS controller in a data center.
EVS Clients
The dladm
and zonecfg
commands are EVS clients. You can define the L2 network topologies through the evsadm
command by using the elastic virtual switch, IPnet, and VPorts. You can use the dladm
command to connect the VNICs to the L2 network topologies, or you can use the zonecfg
command to connect the VNIC anet
resource, thereby connecting the zones to the L2 network topologies.
In OpenStack, the Neutron API service runs on the controller node. The Neutron API service is an EVS client that communicates with the EVS controller installed on the network node.
EVS Nodes (Compute Nodes)
Compute nodes are hosts whose VNICs (or zones whose VNIC anet
resources) connect to an elastic virtual switch, as shown in Figure 2. You can use commands such as dladm
and zonecfg
to specify VNICs that need to be connected to an elastic virtual switch.
In OpenStack, the compute nodes are EVS nodes that connect to the EVS controller on the network node.
Figure 2. EVS nodes connect to an elastic virtual switch
IP Networks
An IPnet represents a block of IPv4 or IPv6 addresses with a default router for the block. This block of IPv4 or IPv6 addresses is also known as the subnet. You can associate only one IPnet to an elastic virtual switch. All VMs that connect to the elastic virtual switch through a VPort are assigned an IP address from the IPnet that is associated with the elastic virtual switch.
You can also manually assign an IP address to a VM by setting the IP address property, ipaddr
, for the VPort. This IP address must be within the subnet range of the IPnet.
VPorts
A VPort represents the point of attachment between a VNIC and an elastic virtual switch. When a VNIC connects to a VPort, the VNIC inherits the network configuration parameters that the VPort encapsulates, such as the following:
- SLA parameters, such as maximum bandwidth, class of service, and priority
- MAC address
- IP address
When you create a VPort, using the evsadm add-vport
subcommand, a randomly generated MAC address and the next available IP address from the associated IPnet are assigned to the VPort. The randomly generated MAC address has a default prefix consisting of a valid IEEE OUI with the local bit set. You can also manually specify the IP address (static IP) and the MAC address while adding a VPort.
Note: Each elastic virtual switch can have multiple VPorts.
Tenants
The elastic virtual switches and their resources are logically grouped together. Each logical group is called a tenant. The defined resources for the elastic virtual switch within a tenant are not visible outside that tenant's namespace. The tenant acts as a container to hold all the tenant's resources together.
Note: Each tenant can have multiple elastic virtual switches.
For testing or non-production environments, you can install all the EVS components on a single system.
This article will demonstrate how to set up two compute nodes (compute-node1
, compute-node2
) that host four Oracle Solaris Zones (z1
, z2
, z3
, z4
), as shown in Figure 3 and described in Table 1.
In addition, we will set up two elastic virtual switches (HR
, ENG
) across the two compute nodes for two cloud tenants (tenantA
, tenantB
), as shown in Figure 4 and described in Table 1.
Table 1. EVS components
Compute Node Name | Zone Name | VNIC Name | IP Address | Elastic Virtual Switch Name | Tenant Name |
compute-node1 | z1 | z1/net0 | 192.168.100.2 | HR | tenantA |
compute-node1 | z2 | z2/net0 | 192.168.200.3 | ENG | tenantB |
compute-node2 | z3 | z3/net0 | 192.168.100.3 | HR | tenantA |
compute-node2 | z4 | z4/net0 | 192.168.200.2 | ENG | tenantB |
Figure 3. Architecture we will use
Figure 4. Elastic virtual switches we will use
Note: The compute nodes can be an x86 box, an Oracle VM Server for SPARC root domain, or an I/O domain. If the compute node is a guest domain, see the "Networking Constraint" section of this blog.
Important: In the examples presented in this article, the command prompt indicates which user needs to run each command in addition to indicating the environment where the command should be run. For example, the command prompt [email protected]:~#
indicates that user root
needs to run the command from the EVS controller host, which is named evs-controller
In the next sections, we will perform the following operations in order to build the architecture:
- Verify connectively between the nodes (prerequisite).
- Install the EVS packages on the EVS controller and the compute nodes (prerequisite).
- Enable Secure Shell (SSH) connectively between the EVS controller and the compute nodes.
- Set up the EVS controller.
- Configure the first compute node.
- Set up the first zone on the first compute node.
- Set up the second zone on the first compute node.
- Configure the second compute node.
- Set up the third zone on the second compute node.
- Set up the fourth zone on the second compute node.
- Test our final configuration.
Prerequisites
To perform EVS operations, you need to be superuser or a user with the EVS administration rights profile. You can also create a user and assign the EVS administration rights profile to the user. For more information, see Securing Users and Processes in Oracle Solaris 11.2.
Verify Connectivity Between the Nodes
The EVS controller relies on a fully qualified domain name (FQDN) to connect to the host to modify VPort properties. You should verify that every compute host is able to connect to the EVS controller using the controller's FQDN name. You can use the ping
command in order to verify network connectivity.
For example, to verify network connectively between compute-host1
and the evs-contoller
host, run the following command:
[email protected]:~# ping evs-controller.oracle.com
evs-controller.oracle.com is alive
To verify network connectively between compute-host2
host, run the following:
Install Packages on the EVS Controller
You must use only one controller to manage all the elastic virtual switches in a data center. You must install the pkg:/service/network/evs package
and the pkg:/system/management/rad/module/rad-evs-controller
package on the system that acts as the EVS controller.
To install the packages, open the evs-controller
terminal and use the following commands:
[email protected]:~# pkg install evs
Packages to install: 1
Services to change: 1
Create boot environment: No
Create backup boot environment: No
DOWNLOAD PKGS FILES XFER (MB) SPEED
Completed 1/1 15/15 0.1/0.1 2.3M/s
PHASE ITEMS
Installing new actions 40/40
Updating package state database Done
Updating package cache 0/0
Updating image state Done
Creating fast lookup database working
Creating fast lookup database Done
Updating package cache 1/1
[email protected]:~# pkg install rad-evs-controller
Completed 1/1 7/7 0.1/0.1 2.5M/s
PHASE ITEMS
Installing new actions 32/32
After you install the rad-evs-controller
package, you need to use the following command to restart the rad:local
service to load the EVS controller:
[email protected]:~# svcadm restart rad:local
Then verify the that rad:local
service is online:
[email protected]:~# svcs rad:local
STATE STIME FMRI
online 23:31:51 svc:/system/rad:local
Note: If the EVS manager is on a different node than the EVS controller, you need to install the evs
package on the EVS manager.
Install the evs
Package on the Compute Nodes
Open the compute-node1
terminal and install the evs
package:
Verify that the evs
service is online:
[email protected]:~# svcs evs
STATE STIME FMRI
online 13:02:55 svc:/network/evs:default
Open the compute-node2
package:
Verify that the evs
service is online:
STATE STIME FMRI
Note: You need to repeat these steps for each compute node that you add in the future.
EVS uses the SSH protocol as a secure transport mechanism between the components.
About the evsuser
User
To simplify configuration, a user called evsuser
, who has all the authorizations and privileges to perform EVS operations, is created when you install the evs
package using the pkg install evs
command.
You need SSH authentication with the preshared public key for the evsadm
command to communicate with the EVS controller noninteractively and securely. You need to set up the SSH authentication with the preshared public key for evsuser
between the EVS controller and the EVS nodes, as follows:
- For communication between the EVS nodes and the EVS controller—In the
/var/user/evsuser/.ssh/authorized_keys
file on the EVS controller, for each EVS node, append the public key for theroot
user. You need to append these public keys because thezoneadmd
daemon runs asroot
. This daemon connects to the EVS controller and retrieves configuration information for the VNICanet
resource. For more information, see thezoneadmd
(1M) man page. - For communication between the EVS controller and the EVS nodes—In the
file on each EVS node, append the public key forevsuser
. You need to do this because the EVS controller communicates with each of the EVS nodes for setting VPort properties.
Set Up SSH Authentication Between the EVS Nodes and the EVS Controller
Figure 5 shows SSH authentication between the EVS nodes and the EVS controller, and the subsequent procedure describes how to set up the SSH authentication.
Figure 5. Authentication between the EVS nodes and the EVS controller
1. Generate an RSA key pair on compute-node1
[email protected]:~# ssh-keygen -t rsa
Generating public/private rsa key pair.
Enter file in which to save the key (/root/.ssh/id_rsa):
Enter passphrase (empty for no passphrase):
Enter same passphrase again:
Your identification has been saved in /root/.ssh/id_rsa.
Your public key has been saved in /root/.ssh/id_rsa.pub.
The key fingerprint is:
c0:e8:6d:61:67:13:1b:22:91:e9:5c:f9:af:2f:70:65 [email protected]
2. Copy the public key from the /root/.ssh/id_rsa.pub
file on compute-node1
to the /var/user/evsuser/.ssh/authorized_keys
file on the EVS controller.
[email protected]:~# scp /root/.ssh/id_rsa.pub [email protected]:/var/user/evsuser/.ssh/authorized_keys
The authenticity of host 'evs-controller)' can't be established.
RSA key fingerprint is e8:87:92:a6:30:38:d7:bf:af:13:99:b7:33:1a:4e:58.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added 'evs-controller' (RSA) to the list of known hosts.
Password:
id_rsa.pub 100% |*****************************| 400 00:00
3. Log in to the EVS controller as evsuser
from compute-node1
to verify whether the SSH authentication is set up.
[email protected]:~# ssh [email protected]
Oracle Corporation SunOS 5.11 11.2 June 2014
The output shows that you can log in to the EVS controller as evsuser
from compute-node1
without a password.
Enter the exit
command in order to log out from the evs-controller
host and return to compute-node1
[email protected]:~$ exit
Connection to evs-controller.oracle.com closed.
4. Generate an RSA key pair on compute-node2
5. Copy the public key from the /root/.ssh/id_rsa.pub
file on compute-node2
and append it to the /var/user/evsuser/.ssh/authorized_keys
[email protected]:~# cat /root/.ssh/id_rsa.pub | ssh [email protected] 'cat >> /var/user/evsuser/.ssh/authorized_keys'
The authenticity of host 'evs-controller.oracle.com ' can't be established.
Warning: Permanently added 'evs-controller.oracle.com (RSA) to the list of known hosts.
Password:
6. Log in to the EVS controller as evsuser
from compute-node2
Last login: Sun Sep 21 07:33:18 2014 from p4259-04.us.ora
from compute-node2
without a password.
Enter the exit
host and return to compute- node2
7. Generate an RSA key pair in the EVS controller.
8. Copy the public key from the /root/.ssh/id_rsa.pub
file and append it to the /var/user/evsuser/.ssh/authorized_keys
[email protected]:~# cat /root/.ssh/id_rsa.pub >> /var/user/evsuser/.ssh/authorized_keys
9. From the EVS controller, log in to the EVS controller as evsuser
Last login: Tue Oct 21 02:34:51 2014
Enter the exit command in order to log out from the evsuser
account:
Set Up SSH Authentication Between the EVS Controller and the EVS Nodes
Figure 6 shows SSH authentication between the EVS controller and the EVS nodes, and the subsequent procedure describes how to set up the SSH authentication.
Figure 6. Authentication between the EVS controller and the EVS nodes
1. Become the evsuser
user on the EVS controller.
[email protected]# su - evsuser
2. Generate an RSA key pair on the EVS controller for evsuser
[email protected]$ ssh-keygen -t rsa
3. Copy the public key from the /var/user/evsuser/.ssh/id_rsa.pub
file on the EVS controller to the /var/user/evsuser/.ssh/authorized_keys
Note: You need to provide the root password of compute-node1
[email protected]:~$ scp /var/user/evsuser/.ssh/id_rsa.pub [email protected]:/var/user/evsuser/.ssh/authorized_keys
The authenticity of host 'compute-node1 (10.129.195.32)' can't be established.
RSA key fingerprint is 2f:f6:c9:1d:30:5f:f5:8c:19:70:5a:27:83:ab:f6:24.
Warning: Permanently added 'compute-node1,10.129.195.32' (RSA) to the list of known hosts.
Password:
id_rsa.pub 100% |*****************************| 404 00:00
4. Repeat the equivalent of Step 3 for compute-node2
Note: You need to provide the root password of compute-node2
The authenticity of host 'compute-node2 (10.129.195.22)' can't be established.
RSA key fingerprint is 83:3a:63:ea:bb:38:bd:5f:e8:10:f1:81:da:55:09:9e.
Warning: Permanently added 'compute-node2,10.129.195.22' (RSA) to the list of known hosts.
Password:
5. Repeat the equivalent of Step 3 for the EVS controller:
[email protected]:~$ cat /var/user/evsuser/.ssh/id_rsa.pub >> /var/user/evsuser/.ssh/authorized_keys
6. Verify the SSH setup:
Log in to compute-node1
as evsuser
from the EVS controller to verify whether the SSH authentication is set up:
[email protected]:~$ ssh [email protected]
The output shows that you can log in to the node as evsuser
from the EVS controller without a password.
Enter the exit command to log out from compute-node1
and return to the EVS controller.
Connection to compute-node1 closed.
Log in to compute-node2
as evsuser
Enter the exit command to log out from compute-node2
Connection to compute-node2 closed.
After you set up the SSH authentication, you need to specify the EVS controller and set the EVS controller's properties. The assumption is that the controller property is set to ssh://[email protected] on the EVS nodes, the EVS manager, and the EVS controller.
1. Specify the EVS controller:
[email protected]:~# evsadm set-prop -p controller=ssh://[email protected]
Then verify the modification:
[email protected]:~# evsadm show-prop
PROPERTY PERM VALUE DEFAULT
controller rw ssh://[email protected] -
You can see from the command output that the evs-controller.oracle.com
host is the EVS controller.
2. Set the EVS controller properties:
First, determine whether you want to implement the elastic virtual switch using a VLAN, a VXLAN, or both. Then set the properties for the corresponding type of L2 topology that must be used for the elastic virtual switch. This example uses a VXLAN.
If you use a VXLAN to implement the elastic virtual switch, you need to set the vxlan-range
and uplink-port
properties or the vxlan-addr
property.
Optionally, you can also set the vxlan-mgroup
property, which specifies the multicast address that needs to be used. The VXLAN link will use this address to discover other VXLAN links on the same VXLAN segment. If this property is not set, the default all-host address (224.0.0.1) will be used by the VXLAN link.
Optionally, you can set the vxlan-ipvers
property if you want to set up IPv6 addresses. The default is to set up IPv4 addresses:
[email protected]:~# evsadm set-controlprop -p l2-type=vxlan
Set the VXLAN range:
[email protected]:~# evsadm set-controlprop -p vxlan-range=200-300
Set the uplink-port
property to specify the data link that is used for the VXLAN. On top of this data link, the EVS nodes' VNICs will be created by the EVS controller. In the following example, all the EVS nodes will use net2
as the uplink port:
[email protected]:~# evsadm set-controlprop -p uplink-port=net2
Note: If you are using VXLAN as the layer 2 topology, you need to create an IP interface on data link net2
on all the EVS nodes. (A VXLAN link is a virtual link that is created over an IP interface that will be used for receiving and transmitting VXLAN packets.) We will do this in a later step.
If the EVS nodes do not have the same data link, then for every EVS node, you need to specify the data link for the uplink-port
property. For example, consider two compute nodes, compute-node1
with the data link net2
and compute-node2
with the data link net3
. You need to specify the data links of both the hosts when you set the uplink-port
property, as follows:
[email protected]:~# evsadm set-controlprop -h compute-node1.oracle.com -p uplink-port=net2
[email protected]:~# evsadm set-controlprop -h compute-node2.oracle.com -p uplink-port=net3
(Optional) In order to add high availability to the EVS nodes, you can set up the uplink port on top of link aggregation, as shown in Figure 7.
Figure 7. Setting up link aggregation
For example, run the following command to set up the uplink port for a link aggregation named aggr0
that has been configured on compute-node1
[email protected]:~# dladm show-link aggr0
LINK CLASS MTU STATE OVER
aggr0 aggr 1500 up net0 net1 net2 net3
[email protected]:~# evsadm set-controlprop -h compute-node1-p uplink-port=aggr0
For more information, see "Using Datalink Multipathing to Add High Availability to Your Network."
Once you completed the EVS configuration, you can verify the EVS controller properties:
[email protected]:~# evsadm show-controlprop -p l2-type,vxlan-range,uplink-port
PROPERTY PERM VALUE DEFAULT HOST
l2-type rw vxlan vlan --
uplink-port rw net2 -- --
vxlan-range rw 200-300 -- --
You can see that we are using VXLAN for the L2 topology and the uplink port is net2
. In addition, VXLAN IDs 200 through 300 have been set aside for elastic virtual switches.
3. Create the elastic virtual switch HR for the tenant tenantA
[email protected]:~# evsadm create-evs -T tenantA HR
Then verify the switch creation:
[email protected]:~# evsadm show-evs HR
EVS TENANT STATUS NVPORTS IPNETS HOST
HR tenantA idle 0 -- --
The following columns are shown in the output:
EVS
: The name of the elastic virtual switch.TENANT
: The name of the tenant that owns the switch.STATUS
: Whether the switch is idle or busy. It is busy if it has at least one VPort that has a VNIC connected to it.NVPORTS
: The number of VPorts associated with the switch.IPNETS
: The list of IP networks associated with the switch. Currently only one IP network can be associated with an elastic virtual switch.HOST
: The list of hosts that the switch spans across.
Note: We didn't create the VPorts and IP networks yet; this is why 0
is shown in the NVPORTS
column and the IPNETS
column is empty.
4. Create the elastic virtual switch ENG
for the tenant tenantB
[email protected]:~# evsadm create-evs -T tenantB ENG
[email protected]:~# evsadm show-evs ENG
ENG tenantB idle 0 -- --
5. Add the hr_ipnet
IP network to the HR elastic virtual switch.
[email protected]:~# evsadm add-ipnet -T tenantA -p subnet=192.168.100.0/24 HR/hr_ipnet
6. Add the eng_ipnet
IP network to the ENG
[email protected]:~# evsadm add-ipnet -T tenantB -p subnet=192.168.200.0/24 ENG/eng_ipnet
7. Verify the IP network creation:
[email protected]:~# evsadm show-ipnet
NAME TENANT SUBNET DEFROUTER AVAILRANGE
HR/hr_ipnet tenantA 192.168.100.0/24 192.168.100.1 192.168.100.2-192.168.100.254
ENG/eng_ipnet tenantB 192.168.200.0/24 192.168.200.1 192.168.200.2-192.168.200.254
NAME
: The name of the IP network along with name of the elastic virtual switch with which it is associated. It's in the form <evsname/ipnetname>
.TENANT
: The name of the tenant that owns the switch.SUBNET
: The IPv4 or IPv6 subnet for the IP network.DEFROUTER
: The IP address of the default router for the given IP network.AVAILRANGE
: A comma-separated list of available IP addresses that can be assigned to VPorts.
8. Add the VPort vport0
to the elastic virtual switch HR
[email protected]:~# evsadm add-vport -T tenantA HR/vport0
9. Add the VPort vport1
to the elastic virtual switch ENG
[email protected]:~# evsadm add-vport -T tenantB ENG/vport1
10. Verify the creation of the VPorts.
[email protected]:~# evsadm show-vport
NAME TENANT STATUS VNIC HOST
HR/vport0 tenantA free -- --
ENG/vport1 tenantB free -- --
NAME
: The name of the VPort along with name of the elastic virtual switch with which it is associated. It's of the form <evsname/vportname>
.TENANT
: Whether the VPort is used or free. A VPort is used if it has a VNIC associated with it. Otherwise, it's free.VNIC
: The name of the VNIC associated with the VPort.HOST
: The host that has the VNIC associated with the VPort.
11. Verify the elastic virtual switches that were created for tenantA
and tenantB
NAME TENANT STATUS VNIC IP HOST
HR tenantA idle -- hr_ipnet --
vport0 -- free -- 192.168.100.2/24 --
ENG tenantB idle -- eng_ipnet --
vport1 -- free -- 192.168.200.2/24 --
12. Check the MAC address and the IP address associated with HR/vport0
[email protected]:~# evsadm show-vportprop -p macaddr,ipaddr HR/vport0
NAME TENANT PROPERTY PERM VALUE DEFAULT POSSIBLE
HR/vport0 tenantA ipaddr r- 192.168.100.2/24 -- --
HR/vport0 tenantA macaddr r- 2:8:20:6c:9b:af -- --
ipaddr
represents the IP address associated with the VPort. When a VNIC connects to a VPort, this address will be applied to the VNIC. By default, the EVS controller will automatically select an IP address from the IP network associated with the elastic virtual switch. If a zone or VNIC needs to be assigned a particular IP address, that can be achieved by manually setting the ipaddr
property to the desired IP address when the VPort is added to the elastic virtual switch.
Note: Once a VPort is created, its IP address cannot be changed through the evsadm set-vportprop
command.
macaddr
represents the MAC address associated with the VPort. The VNIC that connects to this VPort basically inherits the MAC address from the VPort. By default, the EVS controller will generate a random MAC address for the VPort. If a VNIC needs to be assigned a particular MAC address, that can be achieved by manually setting the macaddr
property to the desired MAC address when the VPort is added to the elastic virtual switch.
Note: Once a VPort is created, its MAC address cannot be changed through the evsadm set-vportprop
command.
13. Check the VXLAN segment ID associated with the elastic virtual switches HR
and ENG
[email protected]:~# evsadm show-evs -L
EVS TENANT VID VNI
HR tenantA -- 200
ENG tenantB -- 201
14. Create an IP interface on data link net2
. This interface will be used to encapsulate the VXLAN packets on all the EVS nodes.
Create the IP interface on top of data link net2
[email protected]:~# ipadm create-ip net2
Create a static IPv4 address on the net2
interface:
[email protected]:~# ipadm create-addr -T static -a local=192.168.1.3 net2/addr
Verify the configuration:
[email protected]:~# ipadm show-addr net2
ADDROBJ TYPE STATE ADDR
net2/addr static ok 192.168.1.3/24
The next step is the configuration of the first EVS node, compute-node1
1. Specify the EVS controller.
Note: All the compute nodes should have an FQDN set up. EVS relies on this to connect to the host to modify VPort properties.
Then verify that the evs-controller
host is the EVS controller:
2. Create an IP interface on data link net2
interface:
[email protected]:~# ipadm create-addr -T static -a local=192.168.1.1 net2/addr
net2/addr static ok 192.168.1.1/24
Verify network connectivity between the net2
network interfaces on evs-controller
and compute-node1
[email protected]:~# ping 192.168.1.3
192.168.1.3 is alive
Note: 192.168.1.3 is the IP address of net2
1. Now, let'
