Skip to Main Content
Oracle Database Discussions
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Interested in getting your voice heard by members of the Developer Marketing team at Oracle? Check out this post for AppDev or this post for AI focus group information.
Index issue with or and between when we set one partition index to unusable
Sachin BFeb 19 2010 — edited Feb 22 2010
Need to understand why optimizer unable to use index in case of "OR" whenn we set one partition index to unusable, the same query with between uses index.
“OR” condition fetch less data comparing to “BETWEEN” still oracle optimizer unable to use indexes in case of “OR”
1. Created local index on partitioned table
2. ndex partition t_dec_2009 set to unusable
-- Partitioned local Index behavior with “OR” and with “BETWEEN”
SQL> CREATE TABLE t (
  2    id NUMBER NOT NULL,
  3    d DATE NOT NULL,
  4    n NUMBER NOT NULL,
  5    pad VARCHAR2(4000) NOT NULL
  6  )
  7  PARTITION BY RANGE (d) (
  8    PARTITION t_jan_2009 VALUES LESS THAN (to_date('2009-02-01','yyyy-mm-dd')),
  9    PARTITION t_feb_2009 VALUES LESS THAN (to_date('2009-03-01','yyyy-mm-dd')),
 10    PARTITION t_mar_2009 VALUES LESS THAN (to_date('2009-04-01','yyyy-mm-dd')),
 11    PARTITION t_apr_2009 VALUES LESS THAN (to_date('2009-05-01','yyyy-mm-dd')),
 12    PARTITION t_may_2009 VALUES LESS THAN (to_date('2009-06-01','yyyy-mm-dd')),
 13    PARTITION t_jun_2009 VALUES LESS THAN (to_date('2009-07-01','yyyy-mm-dd')),
 14    PARTITION t_jul_2009 VALUES LESS THAN (to_date('2009-08-01','yyyy-mm-dd')),
 15    PARTITION t_aug_2009 VALUES LESS THAN (to_date('2009-09-01','yyyy-mm-dd')),
 16    PARTITION t_sep_2009 VALUES LESS THAN (to_date('2009-10-01','yyyy-mm-dd')),
 17    PARTITION t_oct_2009 VALUES LESS THAN (to_date('2009-11-01','yyyy-mm-dd')),
 18    PARTITION t_nov_2009 VALUES LESS THAN (to_date('2009-12-01','yyyy-mm-dd')),
 19    PARTITION t_dec_2009 VALUES LESS THAN (to_date('2010-01-01','yyyy-mm-dd'))
 20  );
SQL> INSERT INTO t
  2  SELECT rownum, to_date('2009-01-01','yyyy-mm-dd')+rownum/274, mod(rownum,11), rpad('*',100,'*')
  3  FROM dual
  4  CONNECT BY level <= 100000;
SQL> CREATE INDEX i ON t (d) LOCAL;
SQL> execute dbms_stats.gather_table_stats(user,'T')
-- Mark partition t_dec_2009 to unusable:
SQL> ALTER INDEX i MODIFY PARTITION t_dec_2009 UNUSABLE;
--- Let’s check whether the usable index partition can be used to apply a restriction: BETWEEN
SQL> SELECT count(d)
    FROM t
    WHERE d BETWEEN to_date('2009-01-01 23:00:00','yyyy-mm-dd hh24:mi:ss')
                AND to_date('2009-02-02 01:00:00','yyyy-mm-dd hh24:mi:ss');
SQL> SELECT * FROM table(dbms_xplan.display_cursor(format=>'basic +partition'));
| Id  | Operation               | Name | Pstart| Pstop |
|   0 | SELECT STATEMENT        |      |       |       |
|   1 |  SORT AGGREGATE         |      |       |       |
|   2 |   PARTITION RANGE SINGLE|      |    12 |    12 |
|   3 |    INDEX RANGE SCAN     | I    |    12 |    12 |
--- Let’s check whether the usable index partition can be used to apply a restriction: OR
    FROM t
    WHERE
    (d >= to_date('2009-01-01 23:00:00','yyyy-mm-dd hh24:mi:ss') and d <= to_date('2009-01-01 23:59:59','yyyy-mm-dd hh24:mi:ss'))
    or
    (d >= to_date('2009-02-02 01:00:00','yyyy-mm-dd hh24:mi:ss') and d <= to_date('2009-02-02 02:00:00','yyyy-mm-dd hh24:mi:ss'))
|   2 |   PARTITION RANGE OR|      |KEY(OR)|KEY(OR)|
|   3 |    TABLE ACCESS FULL| T    |KEY(OR)|KEY(OR)|
Regards,
Sachin B.
Comments
Processing
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Mar 22 2010
Added on Feb 19 2010
5 comments
