Problems using JavaMail and activation with Java 1.6
843830Jul 30 2007 — edited May 16 2008Hi,
I have developed an application with a SOAP architecture using Axis. Everything worked fine until I upgrade the JRE version from 1.5 to 1.6. Since then a "javax.activation.UnsupportedDataTypeException: no object DCH for MIME type multipart/related; type="text/xml" " exception is thrown every time I try to connect to the webservices.
Debugging the code I've found that the problem is a null value in the "dch" attribute of the ObjectDataContentHandler object returned by the getInputStream method in the DataHandler class.
When I launch the application using JRE 1.5 this attribute value is "text_plain" and everthing woks ok but when I launch it with JRE 1.6 the attribute has a wonderful "null" value...
Anybody knows what could be the reason for that "null" value?
I've looking for this problem in diferent forums and I believe that could be some kind of incompatibility between the activation version provided with the JRE 1.6 and the JavaMail 1.4 version but I'm not sure.
Thanks in advance!
