Skip to Main Content
Java Card
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Interested in getting your voice heard by members of the Developer Marketing team at Oracle? Check out this post for AppDev or this post for AI focus group information.
Problem with smart card. Return code = 80100066 Need help desperately
843851Jan 25 2008
Hi guys !
Im recently having hell of a time communicating with my smart card reader. I have the towitoko reader 'CHIPDRIVE micro 130 V4.30'. I have installed its drivers and every time i run the TestResMan diagnostic tool, everything works fine.
I have also downloaded the OCF, installed it, and im trying to communicate with the reader. My code looks like :
package cardapp;
* @author evsav
import opencard.core.service.SmartCard;
import opencard.core.service.CardRequest;
import opencard.opt.iso.fs.FileAccessCardService;
import opencard.opt.iso.fs.CardFile;
public class ReadFile {
public static void main(String[] args) {
System.out.println("reading smartcard file...");
try {
SmartCard.start();
// wait for a smartcard with file access support
CardRequest cr =
new CardRequest(CardRequest.NEWCARD, null, FileAccessCardService.class);
SmartCard sc = SmartCard.waitForCard(cr);
FileAccessCardService facs = (FileAccessCardService) sc.getCardService(FileAccessCardService.class, true);
CardFile root = new CardFile(facs);
CardFile file = new CardFile(root, ":c009");
byte[] data = facs.read(file.getPath(), 0, file.getLength());
sc.close();
String entry = new String(data);
entry = entry.trim();
System.out.println(entry);
} catch (Exception e) {
e.printStackTrace(System.err);
} finally { // even in case of an error...
try {
SmartCard.shutdown();
System.exit(0);
I have placed the opencard.properties file into C:\Java\jdk1.6.0_04\jre\lib. Here it is:
# Configuring the CardServiceRegistry
OpenCard.services = com.ibm.opencard.factory.MFCCardServiceFactory
# Configuring the CardTerminalRegistry
# The parameters after the class name are:
# name, type, and address of the card terminal
OpenCard.terminals = com.ibm.opencard.terminal.pcsc10.Pcsc10CardTerminalFactory
#com.ibm.opencard.terminal.pcscmig.PcscMigCardTerminalFactory
# Configuring Tracing
OpenCard.trace = opencard.core:6 opencard.opt:0 com.ibm.opencard:3 \
com.ibm.opencard.terminal.ibm5948.IBM5948CardTerminal:8 opencard.core:3 opencard.core:8 opencard.core:4
As i read, the file 'readers.cfg ' is not necessary as long as i use the Pcsc10CardTerminalFactory as a terminal which i assume is the correct for my reader. Having set the debug mode ON when i run the program i get the following lines (a part of them)
[DEBUG ] opencard.core.service.CardServiceRegistry.getSmartCard
--- message CTEvent opencard.core.event.CardTerminalEvent[source=com.ibm.opencard.terminal.pcsc10.Pcsc10CardTerminal@c20e24
+ name SCM Microsystems Inc. CHIPDRIVE USB SmartCardReader 0
+ type PCSC10
+ addr ]
---source com.ibm.opencard.terminal.pcsc10.Pcsc10CardTerminal@c20e24
+ type PCSC10
+ addr
---id 1
card inserted in slot 0
terminal com.ibm.opencard.terminal.pcsc10.Pcsc10CardTerminal@c20e24
+ type PCSC10
+ addr
--- thread Thread[Thread-0,5,main]
--- source opencard.core.service.CardServiceRegistry@1050e1f++ registered factory com.ibm.opencard.factory.MFCCardServiceFactory@174cc1f
[DEBUG ] com.ibm.opencard.terminal.pcsc10.Pcsc10CardTerminal.openSlotChannel
--- message for slot #0
--- source com.ibm.opencard.terminal.pcsc10.Pcsc10CardTerminal@c20e24
+ type PCSC10
+ addr
and the flow control stops here waiting for me to insert a card. When i insert the card into the reader i get the following exception
opencard.core.terminal.CardTerminalException: Pcsc10CardTerminal: PCSC Exception in method SCardConnect: PC/SC Error SCardConnect
return code = 80100066
[ERROR ] com.ibm.opencard.terminal.pcsc10.OCFPCSC1.OCFPCSC1.SCardConnect
--- message PCSC Exception in method SCardConnect: PC/SC Error SCardConnect
at com.ibm.opencard.terminal.pcsc10.Pcsc10CardTerminal.translatePcscException(Pcsc10CardTerminal.java:502)
--- source com.ibm.opencard.terminal.pcsc10.OCFPCSC1@1027b4d
[DEBUG ] opencard.core.event.EventGenerator.updateCards
--- message notified CTListeners
at com.ibm.opencard.terminal.pcsc10.Pcsc10CardTerminal.cardConnect(Pcsc10CardTerminal.java:361)
--- source class opencard.core.event.EventGenerator
at com.ibm.opencard.terminal.pcsc10.Pcsc10CardTerminal.internalOpenSlotChannel(Pcsc10CardTerminal.java:315)
at opencard.core.terminal.CardTerminal.openSlotChannel(CardTerminal.java:385)
at opencard.core.service.CardServiceRegistry.getSmartCard(CardServiceRegistry.java:316)
at opencard.core.service.SmartCard.getSmartCard(SmartCard.java:388)
at opencard.core.service.CardWaiter.cardInserted(CardWaiter.java:98)
at opencard.core.event.EventGenerator.updateCards(EventGenerator.java:233)
at opencard.core.terminal.CardTerminalRegistry.cardInserted(CardTerminalRegistry.java:281)
[DEBUG ] opencard.core.service.SmartCard.<shutdown>
at opencard.core.terminal.CardTerminal.cardInserted(CardTerminal.java:577)
--- message shutdown OpenCard
--- thread Thread[main,5,main]
--- source class opencard.core.service.SmartCard
at com.ibm.opencard.terminal.pcsc10.Pcsc10CardTerminal.poll(Pcsc10CardTerminal.java:493)
[DEBUG ] opencard.core.terminal.CardTerminalRegistry.remove
at opencard.core.event.EventGenerator.run(EventGenerator.java:199)
--- message closing com.ibm.opencard.terminal.pcsc10.Pcsc10CardTerminal@c20e24
at java.lang.Thread.run(Thread.java:619)
and the rest of the remaining debug lines.
Can pls anyone tell me what does 'return code = 80100066' mean?
Thanks in advance
evsav
Comments
Processing
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Feb 22 2008
Added on Jan 25 2008
0 comments
