My requirement is to develop a screen just like taskflow editor where components can be dragged and then wired to form a logical flow. In the back end it should generate a xml of the diagram , same as it happens in Jdev where you can edit a tasklow-defn.xml in design view and in the source you can see the corresponding xml. Beside that you are shown a component palette from where you can select and drag components.How has this functionality been implemented in jdev ? Is it using adf/swing components ?
Any help would be appreciated.
Awaiting quick response !!!!!!!!!!!!
