Discussions
Categories
- 196.8K All Categories
- 2.2K Data
- 239 Big Data Appliance
- 1.9K Data Science
- 450.3K Databases
- 221.7K General Database Discussions
- 3.8K Java and JavaScript in the Database
- 31 Multilingual Engine
- 550 MySQL Community Space
- 478 NoSQL Database
- 7.9K Oracle Database Express Edition (XE)
- 3K ORDS, SODA & JSON in the Database
- 544 SQLcl
- 4K SQL Developer Data Modeler
- 187K SQL & PL/SQL
- 21.3K SQL Developer
- 295.9K Development
- 17 Developer Projects
- 138 Programming Languages
- 292.5K Development Tools
- 107 DevOps
- 3.1K QA/Testing
- 646K Java
- 28 Java Learning Subscription
- 37K Database Connectivity
- 155 Java Community Process
- 105 Java 25
- 22.1K Java APIs
- 138.1K Java Development Tools
- 165.3K Java EE (Java Enterprise Edition)
- 18 Java Essentials
- 160 Java 8 Questions
- 86K Java Programming
- 80 Java Puzzle Ball
- 65.1K New To Java
- 1.7K Training / Learning / Certification
- 13.8K Java HotSpot Virtual Machine
- 94.3K Java SE
- 13.8K Java Security
- 204 Java User Groups
- 24 JavaScript - Nashorn
- Programs
- 439 LiveLabs
- 38 Workshops
- 10.2K Software
- 6.7K Berkeley DB Family
- 3.5K JHeadstart
- 5.7K Other Languages
- 2.3K Chinese
- 171 Deutsche Oracle Community
- 1.1K Español
- 1.9K Japanese
- 232 Portuguese
Possible error in JRE 8u5 using direct connection to internet using ADSL
We have adapted one applet to work with the new security requirements of JAVA 8 (MANIFEST options).
The new applets adapted works OK with Java 7u55 (in a PC with direct connection to internet using ADSL and a PC using a conection through a Proxy)
But with Java 8u5, the applets wrok in case the connection is done using a Proxy but don't work in case of direct connection to internet using ADSL.
and we get this error:
java.net.SocketException: Connection reset
java.lang.ClassNotFoundException: com.db.CobPag.applets.ImpAEB34_1.class
We test the applets using Windows 7 and IE 10 32 bits.
Is there a problem with JRE 8u5 using direct connection to internet?
Java Console Log.
[email protected]
basic: Listener de progreso agregado: [email protected]
security: Expected Main URL: https://uat-dwebge.www.myweb.com/dbd_cp/applets/impAEB34-1.jar
basic: Plugin2ClassLoader.addURL parent called for https://uat-dwebge.www.myweb.com/dbd_cp/applets/impAEB34-1.jar
network: No se ha encontrado la entrada de caché [URL: https://uat-dwebge.www.myweb.com/dbd_cp/applets/impAEB34-1.jar, versión: null]
network: Conectando https://uat-dwebge.www.myweb.com/dbd_cp/applets/impAEB34-1.jar con proxy=DIRECT
network: No se ha encontrado la entrada de caché [URL: file:/C:/Program%20Files/Java/jre8/lib/ext/sunec.jar, versión: null]
network: No se ha encontrado la entrada de caché [URL: file:/C:/Program%20Files/Java/jre8/lib/ext/sunjce_provider.jar, versión: null]
network: Conectando http://uat-dwebge.www.myweb.com:443/ con proxy=DIRECT
at java.net.SocketInputStream.read(Unknown Source)
at sun.security.ssl.InputRecord.readFully(Unknown Source)
at sun.security.ssl.InputRecord.read(Unknown Source)
at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(Unknown Source)
at sun.plugin.PluginURLJarFileCallBack.connect(Unknown Source)
at sun.plugin.PluginURLJarFileCallBack.retrieve(Unknown Source)
at sun.net.www.protocol.jar.URLJarFile.retrieve(Unknown Source)
at sun.net.www.protocol.jar.URLJarFile.getJarFile(Unknown Source)
at sun.net.www.protocol.jar.JarFileFactory.get(Unknown Source)
at sun.net.www.protocol.jar.JarURLConnection.connect(Unknown Source)
at sun.plugin.net.protocol.jar.CachedJarURLConnection.connect(Unknown Source)
at sun.plugin.net.protocol.jar.CachedJarURLConnection.getJarFileInternal(Unknown Source)
at sun.plugin.net.protocol.jar.CachedJarURLConnection.getJarFile(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath$JarLoader.getJarFile(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath$JarLoader.access$1000(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath$JarLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.deploy.security.DeployURLClassPath$JarLoader.ensureOpen(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath$JarLoader.<init>(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath$3.run(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath.getLoader(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath.getResource(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader$2.run(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.findClassHelper(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadClass0(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.initAppletAdapter(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
network: No se ha encontrado la entrada de caché [URL: https://uat-dwebge.www.myweb.com/cp/CobPag/applets/ImpAEB34_1.class, versión: null]
network: Conectando https://uat-dwebge.www.myweb.com/cp/CobPag/applets/ImpAEB34_1.class con proxy=DIRECT
network: No se ha encontrado la entrada de caché [URL: https://uat-dwebge.www.myweb.com/cp/CobPag/applets/ImpAEB34_1/class.class, versión: null]
network: Conectando https://uat-dwebge.www.myweb.com/cp/CobPag/applets/ImpAEB34_1/class.class con proxy=DIRECT
basic: cargar: clase com.db.CobPag.applets.ImpAEB34_1.class no encontrada.
Ignored exception: java.lang.ClassNotFoundException: com.db.CobPag.applets.ImpAEB34_1.class
