Skip to Main Content
SQL & PL/SQL
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Interested in getting your voice heard by members of the Developer Marketing team at Oracle? Check out this post for AppDev or this post for AI focus group information.
PL/SQL using UTL_HTTP to call a method other than POST, PUT or GET.
PK_UpNorthJun 23 2014 — edited Jun 24 2014
The UTL_HTTP.BEGIN_REQUEST function has the following parameters:
UTL_HTTP.BEGIN_REQUEST (
url                           IN VARCHAR2,
method                   IN VARCHAR2 DEFAULT 'GET',
http_version           IN VARCHAR2 DEFAULT NULL,
request_context      IN request_context_key DEFAULT NULL)
RETURN req;
I have an XML file:                               DataFile.XML
I have a web service:                     http://devweb/XferLocation/Xfer.asmx
I have a web service method:          SaveDocument
The method has 2 parameters:      filepath and filename
I want to us the UTL_HTTP.BEGIN_REQUEST function to call the SaveDocument method in order to transfer the XML File to the location specified in the filepath parameter in the SaveDocument method.  Is this possible?  I have the following code, but when I run it I get the following response:
DECLARE
ERROR at line 1:
ORA-29273: HTTP request failed
ORA-06512: at "SYS.UTL_HTTP", line 1130
ORA-06502: PL/SQL: numeric or value error
ORA-06512: at line 28
DECLARE
  Resp_v      UTL_HTTP.RESP;
  Req_v       UTL_HTTP.REQ;
  ReadResp    CLOB;
  URL_v       VARCHAR2(500);
  FExist      BOOLEAN;
  FLen        NUMBER;
  FName_v     VARCHAR2(500);
  FName_full   VARCHAR2(500);
  Method_v    VARCHAR2(500);
  Dir_v       VARCHAR2(500);
  FPath_v     VARCHAR2(500);
  BSize       BINARY_INTEGER;
  Buffer_v    VARCHAR2(32767);
  EndOFile    BOOLEAN;
BEGIN
  Dir_v       := 'DIR_PLSQL';
  FName_v     := 'DataFile';
  FName_full  := 'DataFile.XML';
  URL_v       := 'http://devweb/XferLocation/Xfer.asmx';
  FPath_v     := '\\WebServer\Files\dev\utlfile\plsql\';
  Method_v    := 'SaveDocument(FPath_v,FName_full)';
  UTL_FILE.FGETATTR(Dir_v, FName_full, FExist, FLen, BSize);
  IF FExist THEN
    DBMS_OUTPUT.PUT_LINE('File Name: '||FName_full||CHR(10)||'File Size: '||FLen||CHR(10)||'Block Size: '||BSize);
    DBMS_OUTPUT.PUT_LINE('Method: '||Method_v);
    Req_v := UTL_HTTP.BEGIN_REQUEST(url => URL_v, method => Method_v);
    UTL_HTTP.SET_HEADER(Req_v, 'Content-Type', 'text/xml; charset=utf-8');
    UTL_HTTP.SET_HEADER(Req_v, 'Content-Length', FLen);
    UTL_HTTP.WRITE_TEXT(Req_v, Dir_v||FName_full);
    Resp_v := UTL_HTTP.GET_RESPONSE(Req_v);
    EndOFile := FALSE;
    LOOP
      EXIT WHEN EndOFile;
      BEGIN
        UTL_HTTP.READ_LINE(Resp_v, Buffer_v);
        IF LENGTH(Buffer_v) > 0 THEN
          DBMS_LOB.WRITEAPPEND(ReadResp, LENGTH(Buffer_v), Buffer_v);
        END IF;
        EXCEPTION WHEN UTL_HTTP.END_OF_BODY THEN
          EndOFile := TRUE;
      END;
    END LOOP;
    UTL_HTTP.END_RESPONSE(Resp_v);
    DBMS_OUTPUT.PUT_LINE(ReadResp);
    UTL_FILE.FRENAME(Dir_v, FName_v||'.XML', Dir_v, FName_v||'.OLD');
  END IF;
END;
Thank you in advance,
Paul
This post has been answered by thomaso on Jun 23 2014
Jump to Answer
Comments
Hub Tijhuis
Answer
2 steps
Generate your select statements
SELECT 'SELECT ''' || T1.OWNER || '.' || T1.TABLE_NAME || '.' || T1.COLUMN_NAME || ':'', ' || T1.COLUMN_NAME || ' FROM ' || T1.OWNER || '.' || T1.TABLE_NAME || ' WHERE ' || T1.COLUMN_NAME || ' = ''' || '%YOUR_COLUMN_VALUE%' || ''';'
FROM SYS.ALL_TAB_COLUMNS T1
WHERE T1.COLUMN_NAME LIKE '%COLUMN_NAME%'
and T1.OWNER LIKE '%SCHEMA_NAME_GOES_HERE%'
ORDER BY T1.OWNER, T1.COLUMN_NAME ;
and then execute that statements.
If your column is a number or a date you must adjust the select statement to get the correct one.
Marked as Answer by verde1030 · Aug 26 2021
Paulzip
I show exactly what you want as the final example in a post I made about using DBMS_XMLGen for dynamic SQL, that is, searching all columns for a specific value.
Billy Verreynne
I like my dynamic SQL served as a DBMS_SQL dish.
SQL> create or replace type TStrings is table of varchar2(4000);
 2 /
Type created.
SQL>
SQL> <<plBlock>>
 2 declare
 3         -- table to process
 4         TABLE_NAME     constant varchar2(30)  := 'EMP';
 5
 6         -- string filter to search for
 7         STRING_FILTER  constant varchar2(10)  := '%E%';
 8
 9         -- for making pretty dynamic SQL
 10         TAB            constant varchar2(1)   := chr(9);
 11         LF             constant varchar2(1)   := chr(10);
 12
 13         c              integer;               -- dbms sql cursor handle
 14         cur            sys_refcursor;
 15         rc             integer;               -- dbms sql return code
 16
 17         colsList       TStrings;              -- string cols to search
 18         buffer         TStrings;              -- string cols matches found
 19         rid            varchar2(50);          -- rowid of row with matching col(s)
 20
 21         -- dynamic SQL
 22         sqlProjection  varchar2(32767);
 23         sqlPredicate   varchar2(32767);
 24         dynamicSQL     varchar2(32767);
 25 begin
 26         -- get the string columns in the table
 27         select
 28                 column_name bulk collect into colsList
 29         from   user_tab_cols
 30         where  table_name = plBlock.TABLE_NAME
 31         and    data_type like '%CHAR%'
 32         order by column_id;
 33
 34         -- if no string colums then skip table
 35         if colsList.count = 0 then
 36                 return;
 37         end if;
 38
 39         -- build dynamic SQL using colums on table
 40         for i in 1 .. colsList.count loop
 41                 if i = colsList.count then
 42                         sqlProjection := sqlProjection||TAB||colsList(i);
 43                 else
 44                         sqlProjection := sqlProjection||TAB||colsList(i)||','||LF;
 45                 end if;
 46
 47                 if i = 1 then
 48                         sqlPredicate := 'from'||TAB||TABLE_NAME||LF;
 49                         sqlPredicate := sqlPredicate||'where'||TAB||colsList(i)||' like :Filter'||LF;
 50                 else
 51                         sqlPredicate := sqlPredicate||'or'||TAB||colsList(i)||' like :Filter'||LF;
 52                 end if;
 53         end loop;
 54         dynamicSQL := 'select rowid as RID, TStrings('||LF||sqlProjection||LF||') as COL'||LF||sqlPredicate;
 55         dbms_output.put_line( LF||'Dynamic SQL:'||LF||dynamicSQL );
 56
 57         -- we need to parse and bind dynamically
 58         c := DBMS_SQL.Open_Cursor();
 59         DBMS_SQL.Parse( c, dynamicSQL, dbms_sql.NATIVE );
 60         DBMS_SQL.Bind_Variable( c, 'Filter', STRING_FILTER );
 61         rc := DBMS_SQL.execute( c );
 62
 63         -- convert to a refcursor - we can use a static coded fetch as we know
 64         -- the SQL projection returned is a rowid and column of type TStrings
 65         cur := DBMS_SQL.to_RefCursor( c );
 66
 67         dbms_output.put_line ( 'Filter: <column> like '''||STRING_FILTER||'''' );
 68         loop
 69                 fetch cur into rid, buffer;
 70                 exit when cur%NotFound;
 71
 72                 -- determine which columns matches
 73                 dbms_output.put( 'Table='||TABLE_NAME||' | rowid='||rid );
 74                 for i in 1 .. buffer.count loop
 75                         if buffer(i) like STRING_FILTER then
 76                                 dbms_output.put( ' | matched='||colsList(i)||' value='||buffer(i) );
 77                         end if;
 78                 end loop;
 79                 dbms_output.put_line( '' );
 80
 81         end loop;
 82         close cur;
 83 end;
 84 /
Dynamic SQL:
       ENAME,
       JOB
) as COL
from   EMP
where  ENAME like :Filter
or     JOB like :Filter
Filter: <column> like '%E%'
Table=EMP | rowid=AAAUR+AABAAAR4ZAAA | matched=JOB value=CLERK
Table=EMP | rowid=AAAUR+AABAAAR4ZAAB | matched=ENAME value=ALLEN | matched=JOB value=SALESMAN
Table=EMP | rowid=AAAUR+AABAAAR4ZAAC | matched=JOB value=SALESMAN
Table=EMP | rowid=AAAUR+AABAAAR4ZAAD | matched=ENAME value=JONES | matched=JOB value=MANAGER
Table=EMP | rowid=AAAUR+AABAAAR4ZAAE | matched=JOB value=SALESMAN
Table=EMP | rowid=AAAUR+AABAAAR4ZAAF | matched=ENAME value=BLAKE | matched=JOB value=MANAGER
Table=EMP | rowid=AAAUR+AABAAAR4ZAAG | matched=JOB value=MANAGER
Table=EMP | rowid=AAAUR+AABAAAR4ZAAI | matched=JOB value=PRESIDENT
Table=EMP | rowid=AAAUR+AABAAAR4ZAAJ | matched=ENAME value=TURNER | matched=JOB value=SALESMAN
Table=EMP | rowid=AAAUR+AABAAAR4ZAAK | matched=JOB value=CLERK
Table=EMP | rowid=AAAUR+AABAAAR4ZAAL | matched=ENAME value=JAMES | matched=JOB value=CLERK
Table=EMP | rowid=AAAUR+AABAAAR4ZAAN | matched=ENAME value=MILLER | matched=JOB value=CLERK
PL/SQL procedure successfully completed.
SQL>
This can be implemented as a pipeline table function, with parameters to specify the schema, tables and value to search for.
Billy Verreynne
The pipeline version:
SQL> select * from table(SearchTables(filter=>'SALE%'));
OWNER      TABLE_NAME COLUMN_NAM ROW_ID               VALUE
BILLYV     DEPT       DNAME      AAAUR8AABAAAPvRAAC   SALES
BILLYV     EMP        JOB        AAAUR+AABAAAR4ZAAB   SALESMAN
BILLYV     EMP        JOB        AAAUR+AABAAAR4ZAAC   SALESMAN
BILLYV     EMP        JOB        AAAUR+AABAAAR4ZAAE   SALESMAN
BILLYV     EMP        JOB        AAAUR+AABAAAR4ZAAJ   SALESMAN
5 rows selected.
SQL> select * from table(SearchTables(filter=>'AL%'));
BILLYV     EMP        ENAME      AAAUR+AABAAAR4ZAAB   ALLEN
1 row selected.
The code:
create or replace type TRowMatch is object(
       owner          varchar2(128),
       table_name     varchar2(128),
       column_name    varchar2(128),
       row_id         varchar2(100),
       value          varchar2(4000)
create or replace type TRowMatchTable is table of TRowMatch;
create or replace function SearchTables( owner varchar2 default user(), tableName varchar2 default '%', filter varchar2 )
return TRowMatchTable pipelined is
       cur            sys_refcursor;
       -- dynamic SQL
begin
       for tabList in(
               select
                       owner, table_name
               from   all_tables
               where  owner like SearchTables.owner
               and    table_name like SearchTables.tableName
               order by 1,2
       ) loop
               select
               from   all_tab_cols
               where  owner = tabList.owner
               and    table_name = tabList.table_name
               order by column_id;
                       exit;
               end if;
               sqlProjection := null;
               sqlPredicate := null;
                       else
                       end if;
                       if i = 1 then
                               sqlPredicate := 'from'||TAB||tabList.table_name||LF;
                       else
                       end if;
               end loop;
               dynamicSQL := 'select rowid as RID, TStrings('||LF||sqlProjection||LF||') as COL'||LF||sqlPredicate; --'
       --     dbms_output.put_line( LF||'Dynamic SQL:'||LF||dynamicSQL );
               DBMS_SQL.Parse( c, dynamicSQL, DBMS_SQL.NATIVE );
               DBMS_SQL.Bind_Variable( c, 'Filter', filter );
       --     dbms_output.put_line ( 'Filter: <column> like '''||STRING_FILTER||'''' );
               loop
                               if buffer(i) like filter then
                                       pipe row(
                                               TRowMatch(
                                                       tablist.owner,
                                                       tabList.table_name,
                                                       colsList(i), rid, buffer(i)
                               end if;
                       end loop;
               end loop;
               close cur;
       end loop;
       return;
end;
1 - 4
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Jul 22 2014
Added on Jun 23 2014
2 comments
