Skip to Main Content
DevOps, CI/CD and Automation
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Problem with APDU via USB Connection
a72f27de-4872-46ad-8849-e06e8b4b2895Jun 17 2015 — edited Oct 15 2015
P.S. My english so poor but .. Please help me!
I want to create an android app to find my micro-usb (smartcard reader device), so I have a problem with receive data in smartcard (I sent an APDU that is 0x... to smartcard by method usbDeviceConnection.bulkTransfer. But I dont know how to receive data or something that answer back (It have to answer a data in card back to me after i sent command). And when it answer back how can I encode or translate hex to string ?
I guess, (ref from code) I have a 2 endpoint so i have question about endpointIn and endpointOut. What are these params? How can I use it to send and receive data between device and app ? I think right, or not? And what is BroadcastReceiver do ?
Please give me some advise to solve this problem.
Thank you so much.
protected void onCreate(Bundle savedInstanceState) {
   super.onCreate(savedInstanceState);
  setContentView(R.layout.activity_main);
   tv = (TextView) findViewById(R.id.textview);
   btnLED = (ToggleButton) findViewById(R.id.ledbutton);
   btnLED.setOnClickListener(btnLEDOnClickListener);
   //register the broadcast receiver
   mPermissionIntent = PendingIntent.getBroadcast(this, 0, new Intent(ACTION_USB_PERMISSION), 0);
  IntentFilter filter = new IntentFilter(ACTION_USB_PERMISSION);
  registerReceiver(mUsbReceiver, filter);
  registerReceiver(mUsbDeviceReceiver, new IntentFilter(UsbManager.ACTION_USB_DEVICE_ATTACHED));
  registerReceiver(mUsbDeviceReceiver, new IntentFilter(UsbManager.ACTION_USB_DEVICE_DETACHED));
  connectUsb();
private void connectUsb() {
  Toast.makeText(MainActivity.this,
   "connectUsb()",
  Toast.LENGTH_LONG).show();
  searchEndPoint();
   if (usbInterfaceFound != null) {
  setupUsbComm();
   threadUsbTx = new ThreadUsbTx(usbDeviceConnection, endpointOut);
   threadUsbTx.start();
   threadUsbTx.insertCmd(
   new byte[]{(byte) 0xA0, (byte) 0xA4, 0x00, 0x00, 0x02, 0x3F, 0x00});
   new byte[]{(byte)0x80, (byte)0xb0, 0x00, 0x04, 0x02, 0x00, 0x0d});
   new byte[]{0x00, (byte)0xc0, 0x00, 0x00, 0x0d});
class ThreadUsbTx extends Thread {
   boolean running;
  UsbDeviceConnection txConnection;
  UsbEndpoint txEndpoint;
  Queue<byte[]> cmdQueue;
   byte[] cmdToSent;
  ThreadUsbTx(UsbDeviceConnection conn, UsbEndpoint endpoint) {
   txConnection = conn;
   txEndpoint = endpoint;
   cmdQueue = new LinkedList<byte[]>();
   cmdToSent = null;
   running = true;
   public void setRunning(boolean r) {
   running = r;
   public void insertCmd(byte[] cmd) {
   synchronized (cmdQueue) {
   cmdQueue.add(cmd);
   @Override
   public void run() {
   while (running) {
   if (cmdQueue.size() > 0) {
   cmdToSent = cmdQueue.remove();
   if (cmdToSent != null) {
   final int usbResult = usbDeviceConnection.bulkTransfer(
   txEndpoint,
   cmdToSent,
   cmdToSent.length,
   0);
   final String s = new String(cmdToSent);
  String result = null;
   try {
  result = new String(cmdToSent,"TIS620"); // To Thai language
  } catch (UnsupportedEncodingException e) {
  e.printStackTrace();
   final String finalResult = result;
  runOnUiThread(new Runnable() {
   @Override
   public void run() {
   finalResult+" "+String.format("%040x",cmdToSent),
   cmdToSent = null;
Comments
Post Details
Added on Jun 17 2015
0 comments
