Discussions
Categories
- 196.9K All Categories
- 2.2K Data
- 239 Big Data Appliance
- 1.9K Data Science
- 450.3K Databases
- 221.7K General Database Discussions
- 3.8K Java and JavaScript in the Database
- 31 Multilingual Engine
- 550 MySQL Community Space
- 478 NoSQL Database
- 7.9K Oracle Database Express Edition (XE)
- 3K ORDS, SODA & JSON in the Database
- 545 SQLcl
- 4K SQL Developer Data Modeler
- 187K SQL & PL/SQL
- 21.3K SQL Developer
- 295.9K Development
- 17 Developer Projects
- 138 Programming Languages
- 292.6K Development Tools
- 107 DevOps
- 3.1K QA/Testing
- 646K Java
- 28 Java Learning Subscription
- 37K Database Connectivity
- 155 Java Community Process
- 105 Java 25
- 22.1K Java APIs
- 138.1K Java Development Tools
- 165.3K Java EE (Java Enterprise Edition)
- 18 Java Essentials
- 160 Java 8 Questions
- 86K Java Programming
- 80 Java Puzzle Ball
- 65.1K New To Java
- 1.7K Training / Learning / Certification
- 13.8K Java HotSpot Virtual Machine
- 94.3K Java SE
- 13.8K Java Security
- 204 Java User Groups
- 24 JavaScript - Nashorn
- Programs
- 442 LiveLabs
- 38 Workshops
- 10.2K Software
- 6.7K Berkeley DB Family
- 3.5K JHeadstart
- 5.7K Other Languages
- 2.3K Chinese
- 171 Deutsche Oracle Community
- 1.1K Español
- 1.9K Japanese
- 232 Portuguese
Tip for "Project Problems"
stainsb
Member Posts: 76
Posting this in case someone else has similar issue when opening the start state projects.
If you open the project and get a dialog box labeled "Project Problems".....
- Click the box "Resolve Problems"
- If the problem reads something like "JDK_1.8" platform could not be found (in JPB_MOOC_Lab*)
- Just click the "Close" button
- Right-click the project name in the Project window and select Properties at the bottom of pop-up menu (will bring up a new dialog box)
- In the Categories window on the left of Project Properties dialog box, click "Libraries"
- This will update the right side of the dialog box
- The top input box is labeled "Java Platform" and if the drop-dow box is highlighted in red-text, the issue is the name of your JDK setup doesn't match the name used by the instructor in his Netbeans instance.
- Simply click the drop-down box and select the platform in black text which is the one your IDE is configured to use.
- This will update the setting in the project and the code should compile fine.
- If not, then this post isn't probably going to help you.
Brent S
Comments
Hi Brent,
Thanks a lot for posting this tip. I've not been able to try out your tip until tonight.
The cable on my laptop has been constantly playing up (i.e., no power when plug into socket) or sudden loss of power in the middle of using my laptop. I ended up having to buy a new cable so that I can do lab1 and quiz 1 without fear of sudden loss of electricity / power on my laptop. Anyway I'll continue to post on the topic I created regarding what I found. Both your tip and my way seem to derive the same result though.
Thanks for your effort.
Carol
