Skip to Main Content
Java Development Tools
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Problem with implementing Maven into WBS(UI components not recognized by JDeveloper)
Robert ŠajinaMay 11 2017 — edited May 11 2017
Hi,
I am having trouble implementing Maven into work breakdown structure.
I have tried working with JDeveloper libraries and dependencies which worked fine, but i want to work with Maven as JDeveloper has support for it, and it would be easier to maintain library and dependencies.
My problem is that when i "install" subsystem and include the subsystem library in my master project i don't see my subsystem task flows. Also happens with templates in Common work space which i can't use in any other project (Master or Subsystem).
I' m not having problems in the Model(Business Components) project where if i create an entity in Common Model i can easily see it in my Subsystem work space when creating View Objects. So the problem only occurs in the view controller project.
I have a declarative component which i included in subsystem and to make it visible in the Components Pallet i had to manually add it in Facelets Tag Libraries (ViewController->Project Properties->Facelets Tag Libraries). When using pure JDeveloper library management it is automatically added.
So i am wonder there is a workaround for templates or task flows, or am I missing something?
I have done some researching and found this post which is similar to my problem, but its not quite clear to me how to make it work.
jsf - Using Maven dependencies in JDeveloper 12c - Stack Overflow
My JDeveloper version is 12.2.1.2.0. with JDeveloper build in Maven 3.2.5.
Comments
aroumeli
Hi,
We require the same: returning raw json from pl/sql procedure. Did you find a solution?
Aaron L.
Hope an amateur like me can help......
To POST json to a clob column we do the following:
INSERT INTO js_table
 (js_column)
VALUES
 (blob_to_clob(:body));
oracle-base.com has a version of the blob_to_clob sql
If you just want to return the json clob, the SELECT-statement User_Z87BQ works for us.
We have pl/sql that build the json by using something like the following:
BEGIN
  APEX_JSON.OPEN_OBJECT;
  APEX_JSON.WRITE('result','success');
  APEX_JSON.WRITE('message','hello world');
  APEX_JSON.CLOSE_OBJECT;
END;
thatJeffSmith-Oracle
just print it with htp.p
aroumeli
That's brilliant Jeff, thank you!
I'm using:
OWA_UTIL.mime_header('application/json', TRUE);
in order to set the correct content-type. Is this the correct way to go?
User_2JVWU
For anyone having the same issue: you could simply return the column which holds JSON as a plain JSON type by using a column name like "{}columnname", see:
SELECT id,
       json "{}json"
  FROM table_with_json
ref: https://www.thatjeffsmith.com/archive/2017/09/ords-returning-raw-json/
User_2JVWU
SELECT id,
       json "{}json"
Olafur T
Create GET handler, type PL/SQL
Some examples of creating output:
begin
  owa_util.status_line(201, '', false);
  owa_util.mime_header('application/json', true);
  htp.prn('{"status": "Item created successfully"}');
end;
begin
  owa_util.status_line(200, '', false);
  htp.prn('{"items":[');
  for i in (select rownum as rn, object_Type, object_name, status from all_objects where owner = 'ORDS_METADATA' fetch next 10 rows only) loop
    if i.rn > 1 then
      htp.prn(',');
    end if;
    htp.prn('{"type": "' || i.object_type || '"');
    htp.prn(',"name": "' || i.object_name || '"');
    htp.prn(',"status": "' || i.status || '"}');
  end loop;
  htp.prn(']}');
end;
declare
  l_arr json_array_t := json_array_t();
begin
  for i in (select object_Type, object_name, status from all_objects where owner = 'ORDS_METADATA' fetch next 10 rows only) loop
    declare
      l_obj json_object_t := json_object_t();
    begin
      l_obj.put('type', i.object_type);
      l_obj.put('name', i.object_name);
      l_obj.put('status', i.status);
      l_arr.append(l_obj);
    end;
  end loop;
  apex_util.prn(l_arr.to_clob);
end;
Regards
Oli
Olafur T
And for posting your CLOB, Jeff has already shown how to do a GET media resource.
This is an alternative way to do POST in PL/SQL, I'm assuming it's an array, change as needed:
 begin
  htp.prn('{"items":');
  for i in (select jsonclob from mytable where id = :id) loop
    apex_util.prn(i.jsonclob);
  end loop;
end;
of course under production, this would be a select into with a no_data_found handler
1 - 8
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Jun 8 2017
Added on May 11 2017
4 comments
