Problem with Berkeley DB JE using JCA
527078Aug 8 2006 — edited Jan 17 2007Hello, dear developers of JE
I have implemented Lucene Indexing on Berkeley DB JE. And I'm using the JBoss as application server. Accessing the Breekely DB using JCA.
The problem arises when i'm calling the Environment.close(). It's displaying following error message.
12:01:39,712 WARN [JBossManagedConnectionPool] Exception destroying ManagedConnection org.jboss.resource.connectionmanager.TxCo
javax.resource.ResourceException: com.sleepycat.je.DatabaseException: Attempt to use non-open Environment object().
at com.sleepycat.je.jca.ra.JEManagedConnection.destroy(JEManagedConnection.java:190)
at org.jboss.resource.connectionmanager.InternalManagedConnectionPool.doDestroy(InternalManagedConnectionPool.java:550)
at org.jboss.resource.connectionmanager.InternalManagedConnectionPool.getConnection(InternalManagedConnectionPool.java:1
at org.jboss.resource.connectionmanager.JBossManagedConnectionPool$BasePool.getConnection(JBossManagedConnectionPool.jav
at org.jboss.resource.connectionmanager.BaseConnectionManager2.getManagedConnection(BaseConnectionManager2.java:410)
at org.jboss.resource.connectionmanager.TxConnectionManager.getManagedConnection(TxConnectionManager.java:342)
at org.jboss.resource.connectionmanager.BaseConnectionManager2.allocateConnection(BaseConnectionManager2.java:462)
at org.jboss.resource.connectionmanager.BaseConnectionManager2$ConnectionManagerProxy.allocateConnection(BaseConnectionM
at com.sleepycat.je.jca.ra.JEConnectionFactoryImpl.getConnection(JEConnectionFactoryImpl.java:56)
at com.sleepycat.je.jca.ra.JEConnectionFactoryImpl.getConnection(JEConnectionFactoryImpl.java:43)
IT WOULD BE HIGHLY APPRECIATED IF EXPLANIN ME THE REASON
Thanks,
Katta
