Forum Stats
  • 3,770,444 Users
  • 2,253,115 Discussions
  • 7,875,457 Comments
Discussions
FSAL Client - which parts / files of JRE-Folder I need for use a FSAL Client, which is not necessary
Norbert.Hein
Norbert.Hein Member Posts: 223 Bronze Badge
edited Feb 19, 2019 11:04AM in Forms Gruppe
Hello,
which parts / files of JRE-Folder I need for use a FSAL Client, which is not necessary ?
I started to configure and testing  FSAL by using this thread  How to start FSAL as signed EXE?
It works fine , thanks very much to Frank Hoffmann ...
To create the local jre I use  jre-8u202-windows-i586.tar.gz
to create a ./jre -folder  with ./jre/bin/  and ./jre/lib/ .
I wonder, All together it needs a space around 170 MB.
Do I need it all ?
Norbert
Answers
  • Juergen Menge
    Juergen Menge Member Posts: 111 Red Ribbon
    Hallo Norbert,
    vermutlich nicht, Du kannst die Server JRE nehmen, die etwas kleiner ist. Allerdings fehlen da einige Klassen (zum Beispiel Java FX), die man allerdings nur braucht, wenn es Java Beans in der Forms-Anwendung gibt, die diese Klassen aufrufen.
    Gruß Jürgen
