Skip to Main Content
ODP.NET
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Problem running dotnet Core Example in VS Code - (ODP.NET Database Connections: Using Connect Descri
user552932Aug 7 2019 — edited Aug 7 2019
Hi there … hope someone can help
I have tried to follow the tutorial (ODP.NET Database Connections: Using Connect Descriptors and Net Service Names) from Alex Keh - https://www.youtube.com/watch?v=k3wLHQALZRk
But find that I am having problems with the Oracle.ManagedDataAccess.Client
Using VS Code
Building an identical console App as in the tutorial – but when try to run get the following error
Exception has occurred: CLR/System.TypeInitializationException
An unhandled exception of type 'System.TypeInitializationException' occurred in Oracle.ManagedDataAccess.dll: 'The type initializer for 'OracleInternal.Common.ProviderConfig' threw an exception.'
Inner exceptions found, see $exception in variables window for more details.
Innermost exception System.IO.FileNotFoundException : Could not load file or assembly 'System.Configuration.ConfigurationManager, Version=0.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51'. The system cannot find the file specified.
at OracleInternal.Common.ConfigBaseClass.GetInstance(Boolean bIsManaged)
at OracleInternal.Common.ProviderConfig..cctor()
Also, see the following in the terminal
Executing task: C:\Program Files\dotnet\dotnet.exe build C:\Users\u203379\MyWork\ASPNet\core_console_ora/core_console_ora.csproj /property:GenerateFullPaths=true /consoleloggerparameters:NoSummary <
Microsoft (R) Build Engine version 15.9.20+g88f5fadfbe for .NET Core
Copyright (C) Microsoft Corporation. All rights reserved.
C:\Users\u203379\MyWork\ASPNet\core_console_ora\core_console_ora.csproj : warning NU1701: Package 'Oracle.ManagedDataAccess 19.3.1' was restored using '.NETFramework,Version=v4.6.1' instead of the project target framework '.NETCoreApp,Version=v2.2'. This package may not be fully compatible with your project.
Restore completed in 28.4 ms for C:\Users\u203379\MyWork\ASPNet\core_console_ora\core_console_ora.csproj.
core_console_ora -> C:\Users\u203379\MyWork\ASPNet\core_console_ora\bin\Debug\netcoreapp2.2\core_console_ora.dll
Terminal will be reused by tasks, press any key to close it.
Here is a screenshot
The code is very simple
using System;
using Oracle.ManagedDataAccess.Client;
using Oracle.ManagedDataAccess.Types;
namespace core_console_ora
class Program
static void Main(string[] args)
Console.WriteLine("Hello World! Lets try and connect to Oracle");
string Development_UserPass = "USer Id=u203379;Password=************;";
string Develoment_Connect = "Data Source=dfargs03-scan:1521/GISAENTW;";
string connectionstring = Development_UserPass + Develoment_Connect ;
OracleConnection con = new OracleConnection();
con.ConnectionString = connectionstring;
con.Open();
OracleCommand cmd = con.CreateCommand();
cmd.CommandText = "select user from dual" ;
OracleDataReader reader = cmd.ExecuteReader();
while (reader.Read())
Console.WriteLine("DB User. " + reader.GetString(0));
Console.WriteLine();
Console.WriteLine("Press 'Enter' to continue");
Console.ReadLine();
But errors at line 17 - OracleConnection con = new OracleConnection();
To add Oracle Maanaged Data Access used:
dotnet add package Oracle.ManagedDataAccess --version 19.3.1
dotnet add package Oracle.ManagedDataAccess --version 19.3.1 --framework netcoreapp2.2
Changing, specifying the framework did not solve the problem
Interestingly, I have also added the extension "Oracle Developer Tools for VS Code" and this works without any problem when I use a full connection string or a connection based on TNSNames.
Can anyone tell me how to eliminate this error ...
Many thanks in advance
Update
Just did the same exercise using Visual Studio 2017
And get the following error from the same line ... OracleConnection con = new OracleConnection();
HResult=0x80131534
Message=The type initializer for 'OracleInternal.Common.ProviderConfig' threw an exception.
Source=Oracle.ManagedDataAccess
StackTrace:
at Oracle.ManagedDataAccess.Client.OracleConnection..ctor()
Inner Exception 1:
FileNotFoundException: Could not load file or assembly 'System.Configuration.ConfigurationManager, Version=0.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51'. The system cannot find the file specified.
This post has been answered by user552932 on Aug 7 2019
Jump to Answer
Comments
Post Details
Added on Aug 7 2019
1 comment
