Skip to Main Content
Data Science & Machine Learning
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Not able to configure reporsitory and create a project in Oracle SQL Developer 19.1 Data Mining opti
User_LR2NASep 23 2019
While configuring Oracle SQL Developer 19.1 and Oracle 18c for data Mining I am facing a small difficulty which stopping me from making further progress.
After adding dmuser(I have set dmuser correctly as per instructions in manual) and right click to create project. I will be getting below screen to log in with SYS user
[This database does not have the Data Miner repository installed.
Would you like to install the repository?
You will be prompted to authenticate as a database administrator to perform this task.]
When I click on Yes then It will ask for keying SYS password. When I provide correct password for SYS user
ORA-01017: invalid username/password; logon denied
I am not sure in spite of giving correct user why it is showing invalid username. I need some guidance on this how to proceed or if I am making any mistake.
Comments
Post Details
Added on Sep 23 2019
6 comments
