Skip to Main Content
APEX
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Issue when running report in APEX. The printing engine could not be reach........
4004953Mar 6 2020
Hello All,
We are trying to generate a report using Bi Publisher in APEX, but the we cant run the report.
Please find error: ORA-20001: The printing engine could not be reached because either the URL specified is incorrect or a proxy URL needs to be specified.
Thanks
Comments
Hello
The Subtree Delete Control (1.2.840.113556.1.4.805) supported by OUD (Supported LDAP Controls - Oracle Fusion Middleware Architecture Reference for Oracle Unified Directory)  might fit your needs.
This control is attached to a delete request to indicate that the specified entry and all descendant entries are to be deleted.
You must have appropriate privileges to do that (admin account)
You can attached control to a ldapdelete using the -J option as described in ldapdelete - Oracle Fusion Middleware Command-Line Usage Guide for Oracle Unified Directory
Sylvain
When closing a thread as answered remember to mark the correct and helpful posts to make it easier for others to find them
900846
Thanks Sylvain.
I tried with this command to delete entries
ldapdelete -J subtreedelete -h localhost -p 1389 -D "cn=Directory Manager" -w password -x ou=ext,ou=users,dc=example,dc=com
There are about 2 lakhs entries inside this OU and it is taking infact it is running since a hr and still it has not completed the operation.
Is there some other setting which i need to do.
regards,
Ram
Hello,
There is no additional thing to do, adding the control should work.
If it takes a very long time to delete thats one thing, if  it never completes and seem to hang this is another thing.
Has it deleted some entries or does it seem to hang w/o deleting any entry ?
Current implementation may be slow with large trees.
If the problem persists, I would encourage you to contact the Oracle Support so that they can investigate
Sylvain
900846
Thanks Sylvain, i have raised an SR and awaiting for the response
1 - 4
Post Details
Added on Mar 6 2020
0 comments
