Categories
- All Categories
- Oracle Analytics Learning Hub
- 30 Oracle Analytics Sharing Center
- 20 Oracle Analytics Lounge
- 242 Oracle Analytics News
- 45 Oracle Analytics Videos
- 16K Oracle Analytics Forums
- 6.3K Oracle Analytics Idea Labs
- Oracle Analytics User Groups
- 90 Oracle Analytics Trainings
- 16 Oracle Analytics and AI Challenge
- Find Partners
- For Partners
ROW COUNT ISSUE WHEN USING CASE STATEMENT IN A COLUMN
Hi,
I have a report which has a case statement in one of the columns. When I use a formula to get row count I am getting an incorrect row count. When I remove this column the report renders showing the correct count. I am using MAX(RCOUNT(1)) and also tried MAX(COUNT(DISTINCT(RCOUNT(1)))). Both of these give the same result. Any ideas anybody? I am on 12c Platform.
Answers
What are you trying to achieve (COUNT)?
Are you taking simple counts or Running Counts (RCOUNT)?
Both are very different. Please check
0 -
Your issue is probably one of the order of aggregation, due to whether your objects are physical or logical, on the case of case statements and aggregation you nearly always need it to be based on physical measures.
My advice would be to create your logic in the rpd if possible, reproduce your case statement based on the physical, then your results will not be spurious.
0
