Add a column to analysis for users to add their note/comments, is this possible?
Thanks
Yes and no: adding a column? Sure. Displaying comments/notes users entered somewhere else and have been stored in a source and modelled accordingly with the business models? Yes.
Adding a column where users add comments directly and save them in OBIEE isn't an out of the box feature.
You would need a 3rd party tool like OBIEE Commenting & Annotation Tool | Collaborate with BITeamwork or https://www.rittmanmead.com/chitchat/ .
Writeback would be a super simplistic way to add comments, an APEX form would be a more powerful way.
All in all: you either need an extra tool or to code things and it will not be as simple as you hope it would be
Thank you Gianni
Hello Oracle Analytics Community, We are investigating a dashboard compatibility issue between Oracle Analytics Server (OAS) 7.6 and OAS 7.0. Some dashboards originally created in Oracle BI 12c can be opened in OAS 7.6 but fail to open after being archived and imported into OAS 7.0. During our investigation, we found the…
Hi all, We’re running into an issue with an on-premises Oracle Analytics Server 2026 integrated with Active Directory and hoping someone has seen this or knows if a patch is available. Environment: Oracle Analytics Server 2026 (on-premises) WebLogic 14.1.2.0.0, JDK 21, Oracle Linux DB-backed catalog (Oracle DB, BIPLATFORM…
We have a requirement Creating a Bar graph using Cost Center Tree hierarchy as prompt/filter. Created a Bar Graph using Cost Center Tree Hierarchy as a prompt. When I'm selecting values through selection steps from Cost Center Tree Hierarchy, the Bar Graph not refreshing as the selected values are not passing to Graph…
I have 2 tabs on the workbook that use the same dataset. I would rather not use 2 different datasets. Can I code an expression filter or something to remove those records?
Can you please help resolve this error. WebLogic version is 12c. OAS is 6.4
