Hi guys,
first of all I want to state my versions I am using for the upcoming scenario / question:
OBIEE: Version 12.2.1.1.0
OBI Administration Tool: Version 12.2.1.1.0
Oracle Essbase: Version 11.1.2.4.008.28
Server OS: Linux RedHat Enterprise Edition 7.9
Yesterday I tried to restart our Oracle BI environment which was successfully running since May 2016 in SSL-mode (SHA2).
The Linux-terminal shows me the following output:
[oracle@xxx bin]$ bi_start
Starting domain; Using domainHome: /opt/oracle/base/product/fmw/user_projects/domains/bi ...
Initializing WebLogic Scripting Tool (WLST) ...
Welcome to WebLogic Server Administration Scripting Shell
Type help() for help on available commands
<Feb 1, 2022 12:21:17 PM CET> <Info> <Security> <BEA-090905> <Disabling the CryptoJ JCE Provider self-integrity check for better startup performance. To enable this check, specify -Dweblogic.security.allowCryptoJDefaultJCEVerification=true.>
<Feb 1, 2022 12:21:17 PM CET> <Info> <Security> <BEA-090906> <Changing the default Random Number Generator in RSA CryptoJ from ECDRBG128 to HMACDRBG. To disable this change, specify -Dweblogic.security.allowCryptoJDefaultPRNG=true.>
<Feb 1, 2022 12:21:17 PM CET> <Info> <Security> <BEA-090909> <Using the configured custom SSL Hostname Verifier implementation: weblogic.security.utils.SSLWLSHostnameVerifier$NullHostnameVerifier.>
Unable to connect to running NodeManager on host: xxx.com, due to: Error occurred while performing nmConnect : Cannot connect to Node Manager. : General SSLEngine problem
Use dumpStack() to view the full stacktrace :
Failed to start one or more Servers
NodeManager (xxx.com:9506): NOT RUNNING
It seems that the NoteManger is still using the pre-defined Oracle certicates which came with the initial installation. For all other components I have actually installed a separate company certificate in the past which is still valid until the end of the year. I guess that the Oracle certicate is not valid anymore and therefore I am not able to start up the NodeManager.
I have already tried to following conslusion:
The connection to the admin server was successful and I was able to perform the synchronisation as described. Unfortunately, there was no change in behavior.
I also tried this approach without any success:
Maybe someone of you has also struggled with the same problem and give me a little hint / help on it?
Best regards and thanks in advance
Carsten
