Is there a way to plan a project on PPM using different calendars in the same way as on MS Project?
Received Response
23
Views
2
Comments
Summary:
On Microsoft Project a project can be scheduled using different calendar on tasks (Task Calendar column).
Is it possible on PPM?
Content (required):
User plans his projects on Microsoft Project assign different calendars to tasks of the same project.
For example, on the same Project one task considers weekends to work and other task does not consider.
Is it possible to plan projects just like can be done on MS Project assigning different calendars to tasks?
23C
Code Snippet (add any code snippets that support your topic, if applicable):
Howdy, Stranger!
Log In
Register
