Issue with Forecast Data Integration Between EPM Planning Project and Project Portfolio Management
Summary:
We are implementing an out-of-the-box (OOTB) EPM Planning solution using the EPM Planning Project module, while our client also utilizes the Oracle Project Portfolio Management Cloud module (PPM).
We have successfully established OOTB integrations between EPM Planning project and Fusion PPM, allowing us to:
- Set up and approve projects in EPM for the "OEP_Plan" scenario.
- Send approved project master data from EPM Planning to PPM.
- Add budget expenses to the "OEP_Plan" scenario in EPM Planning.
- Export project budgets from EPM to Fusion PPM.
- Add actuals in Fusion PPM and import actual expenses back into EPM.
Issue: Forecast Data Integration Limitation
0
