How to load large volume of Project Organization and Project Unit Orgs?
Summary:
Hi,
We are looking to add over 1,000 additional records to our Project Unit Org structure - we are planning to use the export/import .csv file and update the values within the zip files. However there is a unique Organization_ID code that we need to retrieve from HCM.
Is there a simpler way to perform this load?
Thanks,
Gautam
Code Snippet (add any code snippets that support your topic, if applicable):
