Hi,
ODI 11g 117
EDQ 11.1.1.7.4
I am getting following error while running one package from ODI to EDQ. This was running fine for the last one year.
ODI-1226: Step EnterpriseDataQuality 1 fails after 1 attempt(s).
ODI-1241: Oracle Data Integrator tool execution fails.
Caused By: oracle.odi.sdk.opentools.OpenToolExecutionException: java.io.IOException: Failed to retrieve RMIServer stub: javax.naming.ServiceUnavailableException [Root exception is java.rmi.ConnectException: Connection refused to host: XXX.YYY.Z.DDD; nested exception is:
java.net.ConnectException: Connection refused: connect]
at com.oracle.OpenTools.EnterpriseDataQuality.execute(EnterpriseDataQuality.java:123)
at com.sunopsis.dwg.function.SnpsOpenToolFunction.actionExecute(SnpsOpenToolFunction.java:47)
at com.sunopsis.dwg.function.SnpsOpenToolFunction.execute(SnpsOpenToolFunction.java:148)
at com.sunopsis.dwg.dbobj.SnpSessTaskSql.execIntegratedFunction(SnpSessTaskSql.java:3437)
at com.sunopsis.dwg.dbobj.SnpSessTaskSql.executeOdiCommand(SnpSessTaskSql.java:1509)
at oracle.odi.runtime.agent.execution.cmd.OdiCommandExecutor.execute(OdiCommandExecutor.java:44)
at oracle.odi.runtime.agent.execution.cmd.OdiCommandExecutor.execute(OdiCommandExecutor.java:1
Please help.
Regards
Hesh
