Categories
- All Categories
- Oracle Analytics Learning Hub
- 33 Sharing Center
- 22 Oracle Analytics Lounge
- 257 Oracle Analytics News
- 45 Oracle Analytics Videos
- 16.1K Oracle Analytics Forums
- 6.3K Oracle Analytics Idea Labs
- Oracle Analytics User Groups
- 98 Oracle Analytics Trainings
- 16 Oracle Analytics and AI Challenge
- Find Partners
- For Partners
Issue with Error() in informatica -- Need help
- 1. I have the below expression in output port:
IIF(ISNULL( IN_ORG_DESC ),
ERROR('ABC~W_INT_ORG_DS.csv~ORG_DESC~IS NULL FOR~'||IIF(ISNULL(ROW_NUM),'W_INT_ORG_DS.csv - ROW NUMBER '||ROW_NUM,''||ROW_NUM )), IN_ORG_DESC)
- 2.The thing is, when i donot have any null values for field 'IN_ORG_DESC ' , all the rows are loaded into target table successfully.
- 3.When i get null value for the field 'IN_ORG_DESC ', the respective record is loaded into informaitca pre built error table, with the following error mesage:
Transformation [EXP_Extract_WC_Basic_Data_Fact] had an error evaluating output column [IN_ORG_DESC ]. Error message is [<<Expression Error>> [ERROR]:
ABC~WC_BASIC_DATA_F.csv~IN_ORG_DESC ~IS NULL OR LOOK UP COLUMN W_INT_ORG_D.INTEGRATION_ID IS NULL FOR ROW NUMBER~1
... u:ERROR(u:CONCAT(u:'ABC~WC_BASIC_DATA_F.csv~IN_ORG_DESC ~IS NULL OR LOOK UP COLUMN W_INT_ORG_D.INTEGRATION_ID IS NULL FOR ROW NUMBER~',u:IIF(i:ISNULL(u:'1'),u:
CONCAT(u:'WC_BASIC_DATA_F.csv - ROW NUMBER ',u:'1'),u:CONCAT(u:'',u:'1'))))].
Ideally it should load as: ABC~WC_BASIC_DATA_F.csv~IN_ORG_DESC ~IS NULL OR LOOK UP COLUMN W_INT_ORG_D.INTEGRATION_ID IS NULL FOR ROW NUMBER~1
Any ideas pls
Thanks,
Veera
