Oracle Analytics Forum
Welcome to the Oracle Analytics Community: Please complete your User Profile and upload your Profile Picture
Oracle publisher problem with integers and doubles
Received Response
53
Views
3
Comments
Aouadj N
Aouadj N Rank 2 - Community Beginner
Summary
Content
hello every body;
i want to create a report with oracle publisher 11g
I create the model, i check for data every thing is ok.
but when i create the report based on this model there some not displayed.
when i try to check the problem i found this:
1-when the data is double type therse no problem for displaying
2-when the data is integer type, only date whitout camma "," are siplayed : it means: 123 is diplayed: 123,4 is not!!!
i searched but no thing found
plz any solution?
thank you at advance.
Answers
  • BluShadow
    BluShadow Rank 4 - Community Specialist
    to_number is a function that takes either a DATE datatype or a VARCHAR2 datatype and returns a number from it.
    By supplying a numeric datatype it will first implicitly convert it to a string (varchar2) and then to a NUMBER.
    To avoid implicit conversion, you would be better to use the cast function e.g.
    CAST(columnname AS NUMBER)
  • BluShadow
    You do realise that integer values don't have decimal precision?  That's the definition of an integer.
  • Aouadj N
    thank you for your response.
    i have resolved the problem by adding to_number(field) in my views at the database
    and it works fine.
    thank you a lot
