The document describes how to extract data from Fusion through data augmentation in FAW and then use it to build new subject areas .
If your use case is
The basic procedure
The steps you'll need to take include:
- Prerequisite for custom public view objects
- Understanding the source data
- Data Augmentation process
- Data modeling tweaks for a star schema
- Model using Semantic Model Extension
- Create branch
- Create subject area for Quotes
- Create dimensions
- Extend dimension
- Create fact
- Modify subject area
- Re-use the Quotes subject area to create Consumption subject area
- Add dimensions in the Consumption subject area
- Add facts in the Consumption subject area
- Create custom subject area referencing the prebuilt custom Quotes subject area
- Create missing dimensions in the Consumer subject area
- Publish the model
- Validate the model
- Deploy the model
Each of these steps are explained and illustrated in the attached case study and we hope you find the information beneficial.
