Categories
- All Categories
- Oracle Analytics and AI Learning Hub
- 53 Oracle Analytics and AI Sharing Center
- 20 Oracle Analytics and AI Lounge
- 292 Oracle Analytics and AI News
- 57 Oracle Analytics and AI Videos
- 16.4K Oracle Analytics and AI Forums
- 6.5K Oracle Analytics and AI Labs
- Oracle Analytics and AI User Groups
- 116 Oracle Analytics and AI Trainings
- 21 Oracle Analytics and AI Challenge
- Find Partners
- For Partners
Using SSO connection with On Prem Essbase connection
We created a connection to our Essbase source using the BI Admin tool (rpd) and were able to successfully create a subject area and build visualizations within OAC. To create the Essbase connection we used our ADMIN credentials that has access to all data.
Our security requirement is that we need to use Essbase user data security.
The essbase Active Directory is completely separate from our OAC login directory so there is no way to quickly use the SSO option within the BI Admin tool.
Is it even possible to use the SSO option in the tool to use user credentials rather than the ADMIN credentials if the two logins are completely different. Has anyone found a workaround for this issue? Is it possible to have a pop up box appear like when you use the direct connection to Essbase.
Comments
Did you tried the IB blocks, if not please try the same , refer below block for more details -
Regards,
Arjun
0 -
@Conor Murnane -This seems to be duplicate of the below thread:
Kindly close this as duplicate. Thank you.
0
