Oracle Cloud exists in the list of registered standard digital bookkeeping systems ACT for DENMARK
Hi @madhavi Sunkara , welcome to the Oracle Analytics forum.
When asking a question, you get better replies if you share a bit more than just a few words. It maybe does make sense for you because you are working on something, but nobody else can guess what you really mean.
For example, "Oracle Cloud" could be any of the 50+ products that are available in the cloud…
If, like Arjun suggested, your question is about JDE, follow the link he posted.
If not, post more details: a full product name, some context of where you are working and, if you are unsure about the product name, a screenshot often can help figure out what the question is about.
Thanks
Hi @madhavi Sunkara
Thanks for using Oracle Analytics Communities. This is not an correct forum for your question.
Question is more related to JDE application.
Refer - JD Edwards on Oracle Cloud
Regards,
Arjun
Description: Join our Product Management team to learn about new features that are part of 26.R3 Application release of Fusion Data Intelligence (SCM). The session will cover updates on Supply Chain Management and Procurement. Presented by: Anil Sebastian - Senior Director, SCM Product Management, Fusion Data Intelligence…
Good day, please kindly assist. We are creating a graph to calculate the number of assets per milestones. However, the planners have only populated assets for only one milestone from the list of milestones the customer wants to track. Which gives an incorrect view as the project moves past different milestones that it has…
I scheduled the report in OTBI and the agent was run successfully. However, I do not receive the report after the run in my inbox. The addresses are properly recorded, and the report is in an excel format and saved as a pivot table in otbi. What can be the cause?
Anyone has any idea why the OAC documentation on custom viz is not available now? I was able to access till last week - https://docs.oracle.com/en/cloud/paas/analytics-cloud/acsdv/build-package-extension.html. Does this mean OAC doesnt support custom viz or custom workbook extensions?
I made a parameter with letter range values… put it into a dashboard filter. Then I created an expression filter to bind it to my last name column in the table with the image I uploaded here. I am getting the following error??? Invalid Expression. Validation of parameter values failed. A general error has occurred. Message…
Does Oracle Analytics Server 2026 include AI features such as a built-in chatbot or AI Assistant? If not, are there any plans or indications that these AI capabilities will be introduced in a future OAS release?
