Categories
- All Categories
- Oracle Analytics and AI Learning Hub
- 54 Oracle Analytics and AI Sharing Center
- 26 Oracle Analytics and AI Lounge
- 317 Oracle Analytics and AI News
- 57 Oracle Analytics and AI Videos
- 16.4K Oracle Analytics and AI Forums
- 6.7K Oracle Analytics and AI Labs
- Oracle Analytics and AI User Groups
- 121 Oracle Analytics and AI Trainings
- 24 Oracle Analytics and AI Challenge
- Find Partners
- For Partners
ORA-00907: missing right parenthesis https://docs.oracle.com/error-help/db/ora-00907/
Hi Folks,
One of our client requirement is to develop an "An audit report for Requisition", we develop the report but facing issue while adding parameters in the query , the objective is to allow "Multiple Requisition Number and Last Update Date" parameter in the report, but we get this following error while adding the parameter.
"ORA-00907: missing right parenthesis https://docs.oracle.com/error-help/db/ora-00907/"
"and IRB.REQUISITION_NUMBER in (:p_REQUISITION_NUMBER) IS NULL OR IRB.REQUISITION_NUMBER =:p_REQUISITION_NUMBER"
The query contains multiple UNIONS.
Please assist.
Answers
OR IRB.REQUISITION_NUMBER =:p_REQUISITION_NUMBERYou have to decide: it's either a IN condition or a IS NULL condition, you can't have a IN … IS NULL.
If you look at the full query, you should easily see what makes it invalid, it's just SQL…
0 -
Please try the following way to see if there's any betterment.
and ( IRB.REQUISITION_NUMBER in (:p_REQUISITION_NUMBER) IS NULL OR IRB.REQUISITION_NUMBER =:p_REQUISITION_NUMBER )
Hope this help.
Thank you.
0 -
Still getting the same error.
0 -
You have to do it for all the prompts that you are using if you are using similar query for others too.
If possible attach your catalog here so that we will try to replicate in our instance and which will be helpful to get a potential resolution.
Thank you.
0
