Categories
- All Categories
- Oracle Analytics Learning Hub
- 19 Oracle Analytics Sharing Center
- 17 Oracle Analytics Lounge
- 233 Oracle Analytics News
- 44 Oracle Analytics Videos
- 15.9K Oracle Analytics Forums
- 6.2K Oracle Analytics Idea Labs
- Oracle Analytics User Groups
- 87 Oracle Analytics Trainings
- 15 Oracle Analytics Data Visualizations Challenge
- Find Partners
- For Partners
Problem using Essbase Acceleration Wizard
I can access the wizard using the url http://gcsorabidev01:9502/cds/view/faces/Main.jspx successfully. I click populate business models and I can successfully choose a business model. I click populate data sources and I get and error message saying there are no existing data sources. How do I create a data source?
Answers
Do you already have in your RPD a physical source pointing to the embedded Essbase where a previously acceleration wizard deployed a cube?
The idea is to reuse a connection and connection pool of it has been defined already, if it's the first time you use the wizard just deselect the checkbox "Select existing connection from RPD" and enter an application name in the unique field you have on your screen (the app name being the Essbase cube which will be deployed).
0 -
I was having trouble getting a connection to Essbase in the RPD. It is working now.
0
