Failed to connect to Oracle Application using OAD
Sharing the Error details while trying to connect to Oracle Application while creating connection
OAD 5.6
What is this connection trying to connect to? an ADW database or are you trying to connect to RPD to access subject areas in DV?
Trying to connect to our analytics/dv URL's using OAD. Instead of developing projects via URL or /dv/ui/ web brower. I am trying to create project using OAD trying to connect to OAS application
Oracle Applications connections should /analytics I performed a quick test.
OAD 5.6 MacOS connecting to OAS 5.5 = encountered the same error. OAD 5.6 MacOS connectin to OBI 12.2.1.4 = created connection fine, subject area query works fine.
Next, OAD 5.6 Windows 10 connecting to the same OAS 5.5 = created connection fine, subject area query works fine. Next, I went back to try again: OAD 5.6 MacOS connecting to the same OAS 5.5 = created connection fine, subject area query works fine. So, perhaps I had a typo or something I would recommend staying on OAD 5.5 for feature parity with OAS 5.5 for back and for project export/import
Description: Join our Product Management team to learn about new features that are part of 26.R3 Application release of Fusion Data Intelligence (SCM). The session will cover updates on Supply Chain Management and Procurement. Presented by: Anil Sebastian - Senior Director, SCM Product Management, Fusion Data Intelligence…
Good day, please kindly assist. We are creating a graph to calculate the number of assets per milestones. However, the planners have only populated assets for only one milestone from the list of milestones the customer wants to track. Which gives an incorrect view as the project moves past different milestones that it has…
I scheduled the report in OTBI and the agent was run successfully. However, I do not receive the report after the run in my inbox. The addresses are properly recorded, and the report is in an excel format and saved as a pivot table in otbi. What can be the cause?
Anyone has any idea why the OAC documentation on custom viz is not available now? I was able to access till last week - https://docs.oracle.com/en/cloud/paas/analytics-cloud/acsdv/build-package-extension.html. Does this mean OAC doesnt support custom viz or custom workbook extensions?
I made a parameter with letter range values… put it into a dashboard filter. Then I created an expression filter to bind it to my last name column in the table with the image I uploaded here. I am getting the following error??? Invalid Expression. Validation of parameter values failed. A general error has occurred. Message…
Does Oracle Analytics Server 2026 include AI features such as a built-in chatbot or AI Assistant? If not, are there any plans or indications that these AI capabilities will be introduced in a future OAS release?
