We are trying to connect to ADW with OAX_USER using SQL developer but getting error while doing so. But when we try to create connection using OAC DV with same wallet file and OAX_USER. Its working.
@Yogesh Yadav It looks like a network issue. Is your FDI in private or public endpoint?
@Yogesh Yadav Yes, you may also need to run some network tests/curl command from your Client system having SQL Developer to the ADW database and ensure there are no connectivity issues between them.
@Ashish-Oracle FDI is in private endpoint. I am using company VPN to connect. I will check with network team for the firewall part
@FDI_USER @Ashish-Oracle Hi, I am facing the same issue. Can you please guide how did you fix the issue?
@s.datta, last update on this forum was more than a year ago. Advise you to open a new thread with more details.
Hello, I'm looking for some guidance on adding Extensible Flexfields (EFFs) into FDI. I'm particularly looking to add fields from the Additional Assignment Info area (PER_ASSIGNMENT_EXTRA_INFO_M). Has anyone done this and have any guidance to share? The documentation I have found to date has not been very insightful. Thank…
Hello, Am new to FDI but learning. I know that we can access the FDI Workbook (which you normally see in Oracle Analytics - see below) from the Fusion landing page, as demo-ed by one of our consultants. However, how do we do this? I know that in Fusion Security Console, you need to add several application roles in order to…
In an analysis/report, when the Bottom Up Manager details are selected from the hierarchy, the Top Position Person record drops out. This is due to the fact that this top level position does not have a record in the Fusion table : PER_MANAGER_HRCHY_CF which is the source to load OAX$OAC.DW_MANAGER_CF_DH . The requirement…
I want to know how PaaS data can be brought into FDI. Ex : Some customer related information is on PaaS. I want to bring it in FDI to join it with customer data coming from oracle fusion and then build an overall report.
We noticed today that the data augmentation card isn't available for us anymore. Anyone with the same issue? Regards
