Categories
- All Categories
- Oracle Analytics Learning Hub
- 20 Oracle Analytics Sharing Center
- 17 Oracle Analytics Lounge
- 233 Oracle Analytics News
- 45 Oracle Analytics Videos
- 15.9K Oracle Analytics Forums
- 6.2K Oracle Analytics Idea Labs
- Oracle Analytics User Groups
- 87 Oracle Analytics Trainings
- 15 Oracle Analytics Data Visualizations Challenge
- Find Partners
- For Partners
I need help on data conversion and expression
there are $ and decimal values coming in the OBIEE Analysis report. Hence would like to correct data format at OBIEE RPD level. can anyone please guide how to achieve this.
Answers
You'll need to provide a bit more detail if you require any assistance.
Can an you provide some screenshots as a starting point?
0 -
Hi,
OBIEE is not really the place where to do data cleansing because OBIEE doesn't store data ... So the cleansing process is done again and again each time to run an analysis.
As Joel said would also help if you give some extra pieces of information ... I assume you maybe means you get data that are received as varchar because containing the $ sign or a comma to separate decimals instead of dot and things like that and you want to translate them back to numbers?
Post some examples of what you have and what you would like to have, but really try to move that task on the DB / sources side as at least you do it once and it's done.
0
