Categories
- All Categories
- Oracle Analytics Learning Hub
- 33 Sharing Center
- 22 Oracle Analytics Lounge
- 258 Oracle Analytics News
- 45 Oracle Analytics Videos
- 16.1K Oracle Analytics Forums
- 6.3K Oracle Analytics Idea Labs
- Oracle Analytics User Groups
- 98 Oracle Analytics Trainings
- 16 Oracle Analytics and AI Challenge
- Find Partners
- For Partners
OBIEE 12c obips1, obis1,obiccs1 and obisch1 not running State: Shutdown
When I am running my start.cmd,
The Node Manager starts, admin manager starts, but comming to bi instance :
OBI Java Host obijh1 Starts and is in running state
But all other component don't start :
obips1
obisch1
obis1
obiccs1
Earlier when i installed it was runnning after that I stopped and few weeks after i started again it raised this issue.
My host file is updated with loopback adapter address.
When i see log files :
<CommonProgramW6432=C:\Program Files\Common Files>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <JAVA_USE_64BIT=true>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <tag2=/listen-port>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <COHERENCE_HOME=C:\Oracle\MIDDLE~1\ORACLE~1\coherence>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <ENV_JAVA_HOME=C:\PROGRA~1\Java\JDK18~1.0_5>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <ORACLE_OBIJH_HOSTS=acl425.arowana.com:9510>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <SystemRoot=C:\Windows>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <TEMP=C:\Users\AKSHAY~1.BHA\AppData\Local\Temp>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <USERPROFILE=C:\Users\akshay.bhan>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <JVM_ARGS= -DORACLE_HOME=C:\Oracle\MIDDLE~1\ORACLE~1\ORACLE~1 -Xms32m -Xmx1024m >
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <TMP=C:\Users\AKSHAY~1.BHA\AppData\Local\Temp>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <ANT_CONTRIB=C:\Oracle\MIDDLE~1\ORACLE~1\oracle_common\modules\net.sf.antcontrib_1.1.0.0_1-0b3>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <ORACLE_BI_SECURITY_SOAP_URLS=http://acl425.arowana.com:9505/bi-security/service>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <ODBCINI=C:\Oracle\Middleware\Oracle_Home\bi\bin\..\..\user_projects\domains\bi\config\fmwconfig\bienv\core\odbc.ini>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <PROFILE_CLASSPATH=C:\Oracle\MIDDLE~1\ORACLE~1\wlserver\server\lib\weblogic.jar>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <UTILS_MEM_ARGS=-Xms32m -Xmx1024m>
<Mar 1, 2017 8:52:42 PM IST> <INFO> <NodeManager ComponentManager> <ORACLE_OBICCS_HOSTS=acl425.arowana.com:9508>
<Mar 1, 2017 8:52:44 PM IST> <INFO> <NodeManager ComponentManager> <The server 'obips1' with process id 4496 is no longer alive; waiting for the process to die.>
<Mar 1, 2017 8:52:44 PM IST> <FINEST> <NodeManager ComponentManager> <Process died.>
<Mar 1, 2017 8:52:44 PM IST> <INFO> <NodeManager ComponentManager> <Server failed during startup. It may be retried according to the auto restart configuration.>
<Mar 1, 2017 8:52:44 PM IST> <FINEST> <NodeManager ComponentManager> <get latest startup configuration before deciding/trying to restart the server>
<Mar 1, 2017 8:52:44 PM IST> <INFO> <NodeManager ComponentManager> <Server failed so attempting to restart (restart count = 1)>
<Mar 1, 2017 8:52:44 PM IST> <INFO> <NodeManager ComponentManager> <Execute:C:\Oracle\Middleware\Oracle_Home\bi\bifoundation\web\bin\sawserver>
<Mar 1, 2017 8:52:44 PM IST> <INFO> <NodeManager ComponentManager> <Executing: C:\Oracle\Middleware\Oracle_Home\bi\bifoundation\web\bin\sawserver>
What am i supposed to do, please guide me.
Answers
1.) Which precise OS version?
1.1.) If any desktop Windows -> read THIS, close this thread and redo with a proper OS
1.2..) If any of the supported server OSs, continue to 2.)
2.) Which precise OBI version?
3.) Have you looked into the log files of the affected components rather than just Node Manager?
0 -
Hi Christian,
It is a desktop windows windows10.
OBIEE 12.2.1.0.0
Yes i have looked into all the log files of affected components, every component is showing me the same error.
What am i supposed to do?
Regards
Akshay Bhan
0 -
Akshay Bhan wrote:It is a desktop windows windows10.
Christian Berg wrote:1.1.) If any desktop Windows -> read THIS, close this thread and redo with a proper OS
Not sure how I can make that any clearer.
Windows 10 is a DESKTOP operating system. It is NOT SUPPORTED to run OBIEE as you can see from the CERTIFICATION MATRIX which I referenced above and again here.
If you want an OBI system to play around with then it's literally a question of minutes to deploy one of the freely available SampleApp virtual machines in - also free - Virtualbox.
Last: If you search the forum you will see that this is the response we give every single time. Desktop OS = not supported. Period.
0 -
Akshay Bhan wrote:What am i supposed to do?
I would download virtualbox and use a VM instead of your own laptop/desktop PC.
Then maybe download SampleApp so it's all setup and working with tons of examples.
If would really want to try a clean install find a trial version of Windows Server (based on certification matrix) or just get a Oracle Linux and do the install into a VM.
Does the install works fine? Good, time to take a snapshot of the VM for when I will break everything so I can revert back here...
0 -
Gianni Ceresa wrote:Does the install works fine? Good, time to take a snapshot of the VM for when *I* will break everything so I can revert back here...
You will break his VM??
0
