Categories
- All Categories
- 15 Oracle Analytics Sharing Center
- 15 Oracle Analytics Lounge
- 214 Oracle Analytics News
- 43 Oracle Analytics Videos
- 15.7K Oracle Analytics Forums
- 6.1K Oracle Analytics Idea Labs
- Oracle Analytics User Groups
- 78 Oracle Analytics Trainings
- 14 Oracle Analytics Data Visualizations Challenge
- Find Partners
- For Partners
SSL Problem with Oracle BI 12c
Hi All,
I have successfully configured SSL with Node Manager,Web Logic and Oracle BI. However, when I tried to enable SSL internal use ,got following error.
./ssl.sh internalssl true
Logging to: /config/middleware/user_projects/domains/bi/bilogs/sslcommand.log
Unable to turn on internal SSL.
Certificates are missing. You should run ssl[.sh] regenerate.
cat /config/middleware/user_projects/domains/bi/bilogs/sslcommand.log
Jul 04, 2018 11:00:49 AM oracle.bi.ssl.pub.SSLRoleConfig <init>
INFO: SSL role config for internal client Trust source: INTERNAL verification: VERIFY_PEER
INFO: SSL role config for external client Trust source: EXTERNAL verification: VERIFY_PEER
Jul 04, 2018 11:00:49 AM oracle.bi.endpointmanager.impl.bienv.BIEnvComponents loadFromInputStream
INFO: Reading components from: /config/middleware/user_projects/domains/bi/config/fmwconfig/bienv/core/bienv-components.xml ...
Jul 04, 2018 11:00:50 AM oracle.bi.ssl.commands.SSLCommand internalSSLCommand
INFO: internalssl command useSSL: true
Jul 04, 2018 11:00:50 AM oracle.bi.ssl.jps.JPSServiceAccessor setJPSConfigLocation
INFO: No JSE config property set, so setting to jse /config/middleware/user_projects/domains/bi/config/fmwconfig/jps-config-jse.xml
Jul 04, 2018 11:00:53 AM oracle.security.jps.JpsStartup start
INFO: Jps initializing.
Jul 04, 2018 11:01:05 AM oracle.security.jps.JpsStartup start
INFO: Jps started.
Jul 04, 2018 11:01:05 AM oracle.security.opss.internal.runtime.ServiceContextManagerImpl getContext
WARNING: Bootstrap services are used by OPSS internally and clients should never need to directly read/write bootstrap credentials. If required, use Wlst or configuration management interfaces.
Jul 04, 2018 11:01:05 AM oracle.bi.ssl.openssl.OpensslCommands <init>
INFO: Running openssl from working directory: /config/middleware/user_projects/domains/bi/tmp/bi/ssl/cmd
Jul 04, 2018 11:01:07 AM oracle.security.audit.Auditor init
WARNING: IAU:IAU-6012: Unable to determine the audit log directory. No log directory specified.
Jul 04, 2018 11:01:07 AM oracle.security.jps.util.JpsUtil disableAudit
INFO: JpsUtil: isAuditDisabled set to true
Jul 04, 2018 11:01:07 AM oracle.security.jps.internal.audit.AuditServiceImpl validateLogPossible
WARNING: No audit log directory is set. Cannot perform audit operations for component JPS.
Please help on this issue.
Thanks in Advance.
Answers
What type of SSL have you configured in CONSOLE?
Can you give some screenshots to better understand it?
0 -
And looking at your error stack have you tried chasing down oracle.security.audit.Auditor to set the audit log location?
0 -
Many Thanks for Reply.
I am using self signed certificate .Please find below screenshots.
bi_server1 keystorkes Tab
bi_server1 SSL tab
0 -
Hi All,
Thanks for your support. Problem get solved automatically .
Although, I have not truned on "internalssl true" despite that able to connect using HTTPS for bi publisher.
0 -
Glad you got your answer, can you close the question please so others don't waste time trying to answer.
0
