Categories
- All Categories
- Oracle Analytics and AI Learning Hub
- 54 Oracle Analytics and AI Sharing Center
- 26 Oracle Analytics and AI Lounge
- 312 Oracle Analytics and AI News
- 57 Oracle Analytics and AI Videos
- 16.4K Oracle Analytics and AI Forums
- 6.7K Oracle Analytics and AI Labs
- Oracle Analytics and AI User Groups
- 117 Oracle Analytics and AI Trainings
- 24 Oracle Analytics and AI Challenge
- Find Partners
- For Partners
Help with a case function on two columns
Hi Experts,
On the below report, I want to sum up all market codes for which the description contains the word Retail.
I thought it is an easy one, but tried several things and always getting a syntax error.
I tried following:
CASE WHEN "Marketing"."Market Description" like '%Retail%' THEN "Marketing"."Market Code"='RETAIL' ELSE Marketing"."Market Code" END
CASE WHEN "Marketing"."Market Code" or "Marketing"."Market Description" like '%Retail%' THEN 'RETAIL' ELSE "Marketing"."Market Code" END
I am not an expert, so pretty sure I am doing some mistakes in thinking there.
Answers
Assuming that you want to create a new "bin" column which aggregates all "retail" members into one:
CASE WHEN "Marketing"."Market Description" like '%Retail%' THEN 'RETAIL' ELSE 'SOMEHTING ELSE' END
or
CASE WHEN "Marketing"."Market Description" like '%Retail%' THEN 'RETAIL' ELSE "Marketing"."Market Description" END
0 -
Hi Christian,
Maybe i was not clear enough. I am using the description to easily identify specific market codes, but basically all i want to group are the market codes based on description.
When description like %Retail%' summarize the market codes and call them RETAIL.
it should summarize (BEN+ECM+MAR+REG) into a market code called RETAIL. I do not need to show the description in the report.
Hope it makes sense
I d
0 -
Don't know if it is possible at all
0 -
Just a hint: As an employee, you have to have your name in your user profile. You can't have a non-sensical user handle.
And the solution is extremely simple if you look at what I wrote and think about it:
Make that:
CASE WHEN "Marketing"."Market Description" like '%Retail%' THEN 'RETAIL' ELSE "Marketing"."Market Code" END
0 -
You can't change the value of a column coming from somewhere else (that's something you should do in a database), what you can do is to have a column with a formula that perform some logic and display one thing or another based on your needs.
CASE WHEN in OBIEE is fairly similar in syntax as to any language having conditions:
CASE WHEN <condition> THEN <value1> ELSE <value2> END
Christian gave you the right condition, he also gave you value1, so instead of using a hardcoded "value2", just use the reference to the column you need to get the value from.
But you can't assign a value with a = in "value 1" or "value 2".
0 -
About 10 seconds: 5 to copy/paste what Christian gave you, 5 to replace one of the values with the column reference you need.
0 -
Thank you Gianni for the suggestion.
I did not appreciated the cinical ton from Christian between colleagues however. I already said, I am not an expert and prefer rather no answer to some arrogant answers.
Below is what Christian suggestion returns. It transforms the description into market codes and group the market codes.
In the pivot table, I then excluded the market.code column, and now I have the revenue summarized by RETAIL market code, which is what I was looking for.
Thanks both
0
